Rocker Bolt Threaded
Jan 16, 2009 | 06:12 PM
Picked up a FRST not too long ago, changed the rocker cover and one felt soft as I took it out. Tightened it all up and it's threaded
Had to be the one right under the throttle body too
Do people usually just helicoil? thinking to re-tap it but not sure on torque settings etc.
Jan 16, 2009 | 09:25 PM
the rocker cover shouldnt be done up tight!! just a slip nip does it for me
Jan 17, 2009 | 11:09 AM
Didn't over tighten it, that bolt felt loose coming out...
Jan 17, 2009 | 11:25 AM
Just whack a 6mm Helicoil in, will never strip again.
Jan 17, 2009 | 11:28 AM
Quality, what I needed to hear
Jan 17, 2009 | 11:34 AM
I always change the threads on the exhaust port side to helicoils, they are indestructable!
Jan 17, 2009 | 08:04 PM
just put a helicoil in
if i remember rigth, torque settings its 7Nm
Jan 17, 2009 | 08:25 PM
does not matter what tightness you do them the bastard things always end up leaking within months lol!
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
deathrider666
Sep 28, 2015 06:12 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
