clearout, plenty of odds & sods *MORE ADDED 21/1*
taking a bit of time out from the cars for a while so i've got together most of the parts i have had sat around for years..... fed up with the clutter in the shed, garage & loft
all sorts of stuff in no order, i will get some pics at the weekend of some of the bits or as requested
3 door sierra front wing, passenger side, brand new gen ford, has a few small dents from storage...£100 prov sold
RS Turbo escort/fiesta recaro seat side upper bolster foam, for the upper part of the seat, comes as both bolsters & the bit above that links them (1 piece) brand new still in the ford bag..£80
escos passenger hockey stick, brand new gen part....£60
hybrid 4x4 saff turbo, was bought brand new, done about 5k then was converted to hybrid spec & not used since, 60 trim comp wheel, 360 bearing, mint housing etc....£300
escos YBP coil packs, done about 2k from new, come with leads & brackets & a set of 1000 mile YBP plugs......£30
escos window seal for opening quater window, brand new...£40
escos whale tail spoiler lower seal, new...£15
escos front brakes, standard calipers & braided hoses with new tarox pads & new black diamond grooved disks, i have a choice of 2 or 4wd disks so would make a good conversion for escort or fiesta turbo £250
4 spoke RS steering wheel, few small scabs on the metal, leather good apart from stretched at the bottom joint, has a bit of tape over that so dosn't notice...£75 (can come with boss to fit RST 3 door/saff of escos/FRST)
brand new escos airbag steering wheel, very dark grey leather with small ford badge on lower spoke...£100
saff bumper tow eye cover, bit tatty but will paint up fine....£10 prov sold
3 door head lamp glass, gen ford, offside x2, £5 each
cosworth phase sensor, new in box, £15
escort mk 6 rear gearbox/ engine mount, new....£20
escort mk 6 brake adjusters, brand new, 1094406....£15
focus front brake pads, fit most mk1 focus except ST/RS, new gen ford, finnis 1425406....£20
focus braided brake hoses, new, goodridge, fit focus 9/00 onwards, brand new....£20
saff cossie rear sunblind, gen ford part, screws to parcel shelf & blinds retract into it, i got it new & was in one of my cars for about a year, only thing is i couldn't find the clips that hold the blinds 'up' to the headlining, you could easily use something else for it...£50
brand new zetec coil, for FRS but will fit most other zetecs (for push on leads) gen ford, still in box...£50
car cover, was perfect for our fiesta turbo, good condition....£10
RS Turbo 'service procedured' booklet......£10
spec-r dump valve with k&n type filter, brand new, has bigger spout for evo but you could use an adaptor of have another spout welded on...£70
focus door handle gaskets, 4 gaskets, enough for a 3 door car, new gen parts in bags still...£10
denon home amp, model PMA 255UK, hardly used....£30
RS Turbo blue/red/white ecu, standard....£50
RS Turbo MSD chip, brand new......£65
escos/3 door clear indicators, mint, come with amber bulbs....£10
saff 4x4 wiper stalk, brand new...£10 prov sold
3 door coin tray, brand new/boxed....£15
aircon thermostat for saff escos, new boxed...£30
mk1 escort tca's, brand new....£20 pair
escos/4x4 saff waterpump to stat hose, new gen ford.....£5
radio tray, non-gen...£5
escos small turbo fuel flap, brand new....£15
saff bumper moulding, new but backing came off 'sticky foam' will be fine if 2 sided foam was refitted...£15
RST fuel metering unit, works fine....£70
saff/escos rad bolts & rubbers, new gen ford, also used for fitting 500 cooler...£10
escos YBP crank sensor, new ford part....£15
ERST orange fan switch, new ford part....£5
zetec breather box/gasket & pcv valve, new....£10
hood stay grommet & black clip....£5
saff/escort 4/5 door switches, (fit in a pillar) new....£5 pair
3 door relay, sure it was for abs, finnis 1659320, purple, new...£5
escort/fiesta turbo clutch lever (box end) later weighted style, new ford part...£5
koni adjustment key...£5
cosworth cambelt tensior, done about 4k, gen part...£10
3 door boot solenoid, new ford part, finnis 1647065.....£20
FRST samco top boost hose with d/v take off & inlet to charge hose, yellow/green colour....£10
fiesta turbo OFAB phase 0 superchip, untested £20
mk2 xr2 wheel cylinders, pair £10
escos small turbo throttle switch, brand new £40
escos heated washer jet, brand new, 1385030 £10
matt grippers (twist locks) that come with gen mats, set of 4, new £5
1800 zetec idle valve, fine on car, £5
AVO suspension top key £5
escort mk5 gear gaitor, perfect to adapt on escos, looks factory £20
RS2000 mk 5/6 fuel rail/injectors/reg brand new £50
t3 turbo-manifold gasket £5
ERST ABS belts, 1 early, 1 late, £5 each
cosworth exhaust manifold gaskets, 2 only, gen ford £8
small battery cover, gen ford £5
'92 spec centre caps, £15 pair
cvh rear rocker cover to breather pipe, new £5
FRST efi injection loom, brand new £20
'92 spec glovebox hinge/clips £15 pair
ERST wheel bearing kit, rear, gen ford, new £8
4x4 front o/s outer diff bearing, gen ford, new £7
frst inner door handle bezel, new, £3
sierra/escort heater rear stat, (controlls heater blower) gen, new £10
3 door heater blower switch, brand new gen £20
escos/4x4 saff engine mount, vgc gen, £10
4x4 saff fuel cap, new, £5
escos/4x4 saff speedo drive (green) new gen part £10
NGK BCR8ES set of 4, new £8
bosch idle air valve, 0280 140 512 £20
5th injector kit, was on erst, runs a cold start valve??? £20?
cosworth rear armplate-chassis, new £5
saff full set (4) jacking covers new, gen £45 prov sold
brass bleed valve, new £10
escos/escort 5/6 tailgate contact pins, new £8
escos o/s side skirt front section, with clip, new £40
cvh sump gasket, new £5
nouveau red touch up kit, gen ford, laquer hard as usual but paint fine, used once £5
mercury grey touch up kit, halfords 3 pen kit, used once, £5
escos 4x4 saff front brake caliper slider boots, caps & spring clips, new gen, £20
S2 ERST inlet-servo vacuum pipe, brand new £10
FRST fuel hose, black plastic, rear of engine bay, finnis 6203 827, new £8
FRST jack eye caps & straps (2) vgc, merc grey, £8
saff gear gaitor, brand new gen part £45
saff 4x4 rev counter, brand new £10
escos fuel filter, new gen part £10
escort cosworth rear lamp gaskets, new genuine, £15 pair
ESCOS,4X4 SAFF standard blue injectors, asnu cleaned/flowed, not used since £45
Focus RS front drop links, new ford parts £35
Escos boost hoses, black SFS, turbo to cooler, T35 to airbox £25
2wd saff speedo drive, brand new £40
escos/4x4 saff thermostat, new gen part, seal missing £20
few pics...
saff 4x4 turbo (housings were moved as it was on erst manifold, easy to put right for 2wd or 4wd)
escort cosworth airbag steering wheel
RS 4 spoke wheel
all sorts of stuff in no order, i will get some pics at the weekend of some of the bits or as requested 3 door sierra front wing, passenger side, brand new gen ford, has a few small dents from storage...£100 prov sold
few pics...
RS 4 spoke wheel
more added, i was getting aomething from the loft last night & found a box of bits up there.......
will try to get some pics this week, not had a chance as yet...
