tappets
Old Jan 15, 2009 | 07:50 PM
OLDSKOOLRYAN's Avatar
OLDSKOOLRYAN
Default tappets
Hi everyone, just had a clutch and sump gasket fitted & now my tappets are noisey. could this be due to them not putting the right sort of oil in my car ? or do i need to change my tappets ? if so whats involved ?
thanks very much
Old Jan 15, 2009 | 08:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes, should be fully synthetic 15w/50 Mobil, Millers, Silkolene or any 3 Ester oil.
If you do have change them then the cam will have to be changed at the same time, cannot change one without the other.
Old Jan 15, 2009 | 08:33 PM
OLDSKOOLRYAN
thanks mate, i will put some 15w 50 mobil one in at the weekend, they where quiet before, do you think this will sort it ?
cheers
Old Jan 15, 2009 | 09:19 PM
adam.d's Avatar
adam.d
Prob put shite oil in the motor when they drained it to do the sump gasket, get it out ASAP and put some good stuff in
Old Jan 15, 2009 | 09:20 PM
kellyalfie's Avatar
kellyalfie
mobil 1 motorsport mate 15 w 50
Old Jan 15, 2009 | 10:37 PM
B16CVH's Avatar
B16CVH
here here
Old Jan 16, 2009 | 05:05 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
what is the best oil for a cvh? i have a zvh in mine im assuming you use the same oil in these 2 engines?
Old Jan 16, 2009 | 05:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
foreigneRS
Technical essay Archives
Jul 20, 2025 05:28 PM
davidfordrs
Sep 21, 2015 04:23 AM
Roosie
Aug 13, 2015 07:40 PM
foreigneRS
Jul 20, 2004 11:29 AM
foreigneRS
Jul 20, 2004 11:06 AM
