Smokey turbo, info needed.
Old Jan 15, 2009 | 02:50 PM
adam.d's Avatar
adam.d
Default Smokey turbo, info needed.
Turbo on my rst has started to smoke. It holds good boost and boosts properly but is obviously not right! there is a tiny amount of up and down play but none in and out. I've been told it may just be an oil seal inside the turbo causing my smoke, is it worth taking it to be fixed or just bin it and buy another?
Old Jan 15, 2009 | 02:54 PM
paul16v's Avatar
paul16v
Monte 087
Still having problems bud? whip it off and take it to turbo active for a check if i was you, think they built the unit thats on your car in the first place.
Old Jan 15, 2009 | 03:00 PM
adam.d's Avatar
adam.d
Been down wennys today to do valve stem seals but it still smokes and he said turbo is the next thing to do. Been on the phone to turbo active but they only seem interested in doing a full rebuuild, if that's gonna cost around £200 I'd sooner just bin it and buy another.
if it's only a seal that'll only cost £50 - £80 I'd have it done if ya know what I mean
Old Jan 15, 2009 | 03:05 PM
paul16v's Avatar
paul16v
Monte 087
I wouldnt bin it mate, is it the same one brucey got built for the car? iirc it was a good spec turbo 360 bearing etc it probably is just the oil seal gone in it it had been sat for a long time
GUZZLER's Avatar
GUZZLER
Its normally around £200 for a rebuild, its sometimes difficult to balance a turbo on old bearings.
Old Jan 16, 2009 | 07:20 PM
mk3cosworth's Avatar
mk3cosworth
now then adam just go get it rebuilt, will be like new and hope its not you piston rings lol
neil18
Mar 14, 2016 01:08 PM
Danielbetty
Oct 3, 2015 06:01 PM
Matt Baxter
Sep 16, 2015 08:30 PM
jonjg
Sep 1, 2015 03:46 PM
Adam-M
22
Aug 10, 2015 10:46 AM
