Fitting rs clocks in base spec mk4
Old Jan 15, 2009 | 07:51 AM
marv's Avatar
marv
Default Fitting rs clocks in base spec mk4
I will soon be fitting some rs turbo clocks into my base spec mk4 escort, i was wondering how id go about wiring up the rev counter?the car has a 2 litre zetec engine fitted and will be running on the standard ignition system.
Old Jan 15, 2009 | 09:07 AM
orion88's Avatar
orion88
dnt know much about the zetecs do they run on a coil pack?
Old Jan 15, 2009 | 10:09 AM
marv's Avatar
marv
yes mate,im running bike carbs so its just the same ignition system as the standard 1.3 hcs,coil pack and a carb! At the moment iv got the speedo and the clock on the lft handside.
Old Jan 15, 2009 | 11:12 AM
RSandy's Avatar
RSandy
assuming we talking as if the clocks were to be fitted to a 1.3 ohv engined base spec, the rs rev counter wont work, even with the link to the coil, it will over-read terribly.
from memory havin read up on doing it on mine years ago, its either a massive wiring job, or judgin by a similar thread in the technical room, u need to source the clocks from a 1.3 eclipse model
Old Jan 15, 2009 | 02:08 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
alright mate its ross here
prev comment was right - you ideally need to source Eclipse clocks, dont ask me why, must be summat to do with them being used with the 1.3 ignition system - i found this out by accident years ago and used them ever since - drying up a bit now though
Old Jan 16, 2009 | 07:55 AM
marv's Avatar
marv
cheers guys
could you explain where i would put the wire from the coil to the clocks?i know that when you fit the zetec engine in a mk2 fiesta and run the esc moduel you can adjust the way the rev counter to suite or wire in some diodes
cheers
Old Jan 16, 2009 | 11:56 AM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
was told the 1.3 stuff dont run to well on a zetec?
its pretty easy to wire in,easiest way is to get some clocks plus the blue and white connectors,u can transfer wire for wire,thn run a wire for rev counter,
Old Jan 16, 2009 | 03:30 PM
marv's Avatar
marv
cheers for that mate
so i need to get the connectors that go to the back of the clocks from an rs turbo loom?
A friend of mine has the same setup in a xr2 and the rev counter reads half the actual revs but the revcounter can be adjusted so il give it a go!
Old Jan 16, 2009 | 03:57 PM
orion_crazy_carl
orion=mini saff
re turbo,xr3i 1.4GL LX ghia,long as its got the rev counter,be the right connection on the back,
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
Dahl88
Aug 22, 2015 08:16 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
