RS Turbo CVH, turbo oil return pipe
What i meant to say was rather than spend the 40 quid on a rubber one only for it to perish and possibly even burst can i get a solid (metal) one for maybe a bit more? do the fessies come with a rubber one aswell?
Jst been through 2 turbo return hoses in as many weeks! What i found was a couple of studs had fallen out of the exhaust housing on the turbo (could not hear the exhaust blowing/leaking). With the studs missing exhaust gas was seeping between the housings directly onto the turbo return hose!
What i have done now is used some 16mm internal diameter oil resistant samco. The only proble is if you try to bend the hose it kinks so i got some copper tube, bent it to 90 degrees and put it inside the samco to stop it kinking.
Replaced the turbo studs and all is well
Yup, the reason the pipes so expensive, is becasue its special impermable rubber, they dont always split, main reasons are that most people use lubilee clips, when the spring clips work just fine.
They do the jubilees up too tight, and it cuts into the rubber
P.S have some spares of these kickin arond
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
