maybe a daft question
Old Jan 13, 2009 | 11:04 PM
dangerousbrian's Avatar
dangerousbrian
Default maybe a daft question
this may sound daft but is there a certain way to bleed the water on the erst? my temp gauge goes right up straight after start up from cold and heaters are warm instantly...i have changed everything i can think of..everything is new that i can think of and been double checked to make sure..even checked the wiring to temp sensor in case it was earthing out somewhere...to bleed off i run car with header tank cap off till fan cuts in..do you peeps do it a different way or have any ideas what it could be or what i should check as i am assuming there is still an air lock..any help much appreciated as its doing my tits in now n want the car on the road after a very long wait...cheers
Old Jan 13, 2009 | 11:10 PM
BigErn's Avatar
BigErn
Ill have a pop along one night after work and have a glimpse if you like?
Old Jan 13, 2009 | 11:23 PM
dangerousbrian
aye spot on ern...its doing me fooking head in now...wanting to get it sorted n set up asap while av still got a bit cash...
Old Jan 13, 2009 | 11:46 PM
BigErn's Avatar
BigErn
Ill come for a glimpse after work tomorrow if I remember
Old Jan 17, 2009 | 09:34 PM
studabear's Avatar
studabear
is the thermostat stuck shut or something like that
Old Jan 17, 2009 | 11:36 PM
orionmojo's Avatar
orionmojo
mines sort of like that, i get warm air within a minute of running and the temp needle is on the "M". however everything works fine. it doesn't overheat and the fan cuts in as normal on the "N" of norm. i just thought it was because of the water feed to the turbo warming it up quicker, wit hit being part of the zorst etc. i dunno tho.
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
