cosworth engine
Old Jan 12, 2009 | 08:40 PM
stigger_darlo's Avatar
stigger_darlo
Default cosworth engine
hi. my mate has chance of a cosworth engine. he said its the one with the red cam cover on it. also has loom gearbox ecu and pretty much everything needed to get it running. does anyone have any idea how much he should be payin. its standard as far as i know cheers
Old Jan 12, 2009 | 08:42 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
id guess at a couple of grand for everything? any history on the engine, proof of mileage or rebuild etc?
Old Jan 12, 2009 | 08:48 PM
stigger_darlo
not sure tbh. he just asked me about it today
Old Jan 13, 2009 | 03:29 PM
ECOS95's Avatar
ECOS95
I'm sure the red tops were the early engines found in the 3dr or saph cosworths, you would want to hear it running as for all you know you could be buying a pile of scrap.
Old Jan 13, 2009 | 03:44 PM
allsteel's Avatar
allsteel
2 grand is far too dear.
Old Jan 15, 2009 | 09:29 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I am guessing that because you are posting in the Escort forum, this might be purchased for one of these cars? If so, unless it has been fitted with a 200 block, it won't be suitable. The 4x4 cars require the extra rigidity achieved with the 200 block, so to fit a 205 blocked engine in one of these cars is likely to result in the block cracking under the twisting stresses that the 4x4 transmission will put on the engine.
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Old ford
Jul 31, 2015 06:50 AM
