Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
GTI wheels on van???
Old Jan 12, 2009 | 05:26 PM
chainsaw's Avatar
chainsaw
Default GTI wheels on van???
Hi all,
A friend has offered me his Escort Gti 5 spokes with 195x50x15's really cheap.
I would love to fit them to my '98 Escort van but am worried they may not fit. Also I'm concerned that they will screw up my speedo.
Anyone fitted these to a van and had any problems?
Cheers.
Old Jan 12, 2009 | 05:37 PM
orionmojo's Avatar
orionmojo
what van is it mate?
and whate size are the wheels.
a 175/70/13 has the same rolling diameter as a 195/50/15 for example, if they're the 15" versions that i'm presuming then you'll be ok.
Old Jan 12, 2009 | 06:12 PM
dazoriginal's Avatar
dazoriginal
prodigal son
should be fine mate as stated
i have a fiesta van running 15" 195/50/
and they have been ok just get the proper studs / bolts
Old Jan 12, 2009 | 08:34 PM
chainsaw's Avatar
chainsaw
Cheers guys.
The wheels are going so cheap that I would be daft to miss the chance.
Should look so much better than my rusty steel wheels.
Old Jan 12, 2009 | 10:55 PM
Dan16v's Avatar
Dan16v
I had them on my mk6 escort van, you have to put longer studs and 10mm spacers on the rears otherwise they scrub on the inside, but other than that they looked great and my speedo was bob on too
Old Jan 13, 2009 | 06:24 AM
.Pete.'s Avatar
.Pete.
mk6 Escort Cab
my wife's still got the standard 14" alloys on her '98 Escort and the speedo is about 4mph out anyway according to satnav, so bigger wheels might actually correct it.
Old Jan 13, 2009 | 06:51 PM
chainsaw's Avatar
chainsaw
Cheers Dan16v,
Spacers will be no problem but how the feck do you change the studs?
Old Jan 14, 2009 | 08:33 PM
chainsaw's Avatar
chainsaw
As an update, I got the wheels today and they fit. Can't get me finger between the tyre and inner rear wheel arch, but they go on with no rubbing. Will get 5mm spacers though just to make sure.
Old Jan 14, 2009 | 08:43 PM
richie mk5's Avatar
richie mk5
im runing cossy wheels on my winter hacker with 6mm spacers no rubbing at all
Old Jan 14, 2009 | 11:01 PM
Dan16v's Avatar
Dan16v
to change the studs you take the rear hubs off and tap the studs out, then tap the new longer ones in, its a pretty easy job
I used 10mm spacers on mine
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Adam Graham
Sep 6, 2015 06:04 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
Bighandsuk
Sep 2, 2015 05:23 PM
