Gearbox probs
Old Jan 11, 2009 | 11:36 PM
becca s2rs's Avatar
becca s2rs
Default Gearbox probs
The gearbox in my s2 is whinning like the missus and just wondered if anyone off here has had any experiences with the rebuild kits on egay? been looking at them for a while now there only £50 or so, so aint to expensive just dont wana strip my box down rebuild it and find out that there made of playdoh when i first use it. Would love a box from cts and be done with it but cant justify all that money for a gearbox, any advice or help of where too get a decent set of bearings and gaskets from would be great. cheers chaps
Old Jan 12, 2009 | 07:25 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
what's the gearbox kit include ?
got a link
Old Jan 12, 2009 | 09:51 AM
antony215's Avatar
antony215
Escort Rs Turbo
I done mine over a year ago now with one them kit's and mines been fine the bearings are SKF ones which is what is in your box from the factory (or atleast the ones i got was)
Old Jan 12, 2009 | 10:53 AM
Turbocabbie
Top Cab !!
How do these kits approach shaft wear as I understand this can be an issue
Old Jan 12, 2009 | 11:02 AM
antony215's Avatar
antony215
Escort Rs Turbo
They dont if your shaft is worn to around 25mm, then it's time to get another shaft However, if it is 27.5mm then it will be fine
Old Jan 12, 2009 | 11:57 AM
becca s2rs's Avatar
becca s2rs
Glad to hear that, did you get all the bearings that are in the box? what about diff bearings? Is there amy special tools needed and what should i look out for when building it?
Old Jan 12, 2009 | 12:09 PM
antony215's Avatar
antony215
Escort Rs Turbo
Yeah you get all the bearings and gaskets. You want a good gear puller set as fith gear is a fucker to get off but apart from that there aint any "special tools" you need. Makesure you check the mainshaft diameter tho as this is what wears alot on rs boxes
Old Jan 12, 2009 | 12:15 PM
becca s2rs's Avatar
becca s2rs
Makesure you check the mainshaft diameter tho as this is what wears alot on rs boxes[/QUOTE]
Nice one, when you say measure the mainshaft do you mean the one you can see coming out the gearbox in the bell housing (ive always called it input shaft thats why im asking) where do you measure it and where does it wear down? thanks for your help
Old Jan 12, 2009 | 12:23 PM
antony215's Avatar
antony215
Escort Rs Turbo
No the other one the one your on about is the input shaft. Measure the end that slots into the bearing if its worn to around 25mm then its fucked (unless you can get a sleeve put on it) but anything around 27.5mm is fine
Old Jan 13, 2009 | 05:06 PM
wing's Avatar
wing
i used fasttrack bearings when i rebuilt mine used one of their uprated kits about £80
Old Jan 13, 2009 | 06:18 PM
coswurv's Avatar
coswurv
Im in the middle of doing mine and i want to upgrade the main shaft and bearing, i know the size and i can get hold of the bearing its just a new mainshaft and sleeve to fit the new bearing, but everywhere i try is so hush hush about where to source the mainshaft and sleeve they dont want to know ? or even worste case for now i would be happy with a new mainshaft and standrad bearing but just cant find out where to get one from, ford themselves ?
Old Jan 14, 2009 | 06:21 PM
wing's Avatar
wing
phone # for fast track bearings is 01902 495250 if you ask them for the uprated bearing with sleeve they do them
Old Jan 14, 2009 | 07:12 PM
coswurv's Avatar
coswurv
After speaking to a few gearbox specialist today i have found some bc 92ca mainshafts, and also found a stockist of the ina bigger bearing (55x27.5x15), so no sleeve is needed to fit the shaft as the shaft end that sits in the roller bering measures 27.5mm as standard.
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
