Flywheel in a zvh?
Old Jan 11, 2009 | 04:35 PM
mikey_clough's Avatar
mikey_clough
Default Flywheel in a zvh?
hi all, ive got 1.8 zvh in my s2 and want to convert to ofab management, question is, can i use a fiesta rs turbo flywheel with the bolt holes oversized to fit the crank, also has the zetec block got the cps hole in the correct place so that i can just put the sensor in without having to machine the block? any help would be great. cheers
Old Jan 11, 2009 | 04:41 PM
rsdan123's Avatar
rsdan123
you can use the FRST flywheel with the holes drilled. i used the zetec gearbox (stronger mainshaft bearing), flywheel and crank sensor with my FRST padle cluch
Old Jan 11, 2009 | 04:53 PM
mikey_clough
how much bigger do the holes need to be made?
Old Jan 11, 2009 | 05:04 PM
rsdan123's Avatar
rsdan123
think its only 1mm. not that hard to do, best using a piller drill..... i have a flywheel alreay done! - i decided to use zetec box + flywheel
Old Jan 11, 2009 | 05:11 PM
mikey_clough
cheers mate, gonna start looking for all the parts i need now.
Old Jan 11, 2009 | 05:15 PM
rsdan123's Avatar
rsdan123
44mins to go
http://cgi.ebay.co.uk/RS-TURBO-OFAB-...QQcmdZViewItem
Old Jan 11, 2009 | 05:28 PM
mikey_clough
thanks for the heads up mate but i wont be buying anything till next month. ran out of money already!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
davidfordrs
Sep 21, 2015 04:23 AM
