Fiesta turbo given a new life
Old Jan 11, 2009 | 09:23 AM
fez016's Avatar
fez016
Default Fiesta turbo given a new life
Hi i use my fez for drag racing and occasional hillclimb event, engine was running 17psi of boost with some minor engine mods. It was running a kent cvh34b cam and a collins powerchip with beige injectors. Best ET 1/4mile was 13.2 seconds @ 112mph and 0-60 in 5.9 secs. Since i do all the work myself i have been able to spend some more on the parts. Here are a few pics:
Engine before:
Engine taken apart
I knew that there was something wrong as the engine was breathing heavily
Also the turbo was found to be busted :
New pistons and rods purchased and engine had to be cut oversize
Also a T34 turbo came along with a .48 housing
Old Jan 11, 2009 | 09:33 AM
Mr.T's Avatar
Mr.T
Good work
Old Jan 11, 2009 | 09:35 AM
fez016's Avatar
fez016
engine started taking shape
Engine block retapped and studded before taken out
Cylinder head taken for a regrind
Polished and ported
new cometic multilayer head gasket to cope with boost:
Also a pair of vibratechnics mounts where purchased:
Old Jan 11, 2009 | 09:41 AM
fez016's Avatar
fez016
battery tray removed with battery now living in the boot
Engine is now ready to be thrown in
and new clutch and pressure plate sourced
Currently rebuilding gearbox so i can put engine in place and therefore start manufacturing the downpipe and exhaust in 2,5 inch stainless steel. Will post more pics as soon as i get some time to spend on my little rocket and ah here is a pic of her in action sometime ago:
will post more pics asap for the attention
Old Jan 11, 2009 | 10:57 AM
MattyRST's Avatar
MattyRST
Looks cool, keep up with the good work
Old Jan 11, 2009 | 09:23 PM
fez016's Avatar
fez016
Originally Posted by JeroentjeRS
Good work
cheers mate i was looking at your thread looks good too
Old Jan 17, 2009 | 10:34 AM
fez016's Avatar
fez016
gearbox opened up and treated with new bearings and lsd diff from an s1. gearbox is an ib5 to which i fitted heavy duty bearings
rose joints where fitted to the lower suspension arms in the quest to eliminate as much torque steer as possible
gearbox painted and engine thrown in place
engine breathing system improved with a bailey breather fitted
Old Jan 17, 2009 | 10:42 AM
fez016's Avatar
fez016
so now started working and manufacturing the down pipe and first half of the exhaust system in stainless steel
so now its only supplying the turbo with oil and manufacturing the drain, installing ecu and harness back in place and then to the most expected moment of them all - the intial start up, wish me luck!!!
Old Jan 17, 2009 | 10:50 AM
AzE_B's Avatar
AzE_B
looking good mate
Old Jan 17, 2009 | 11:20 AM
Nelson's Avatar
Nelson
good work
Old Jan 17, 2009 | 07:20 PM
fez016's Avatar
fez016
thanks for the comments
Old Jan 17, 2009 | 09:02 PM
Nice work mate i bet it goes like fook.
Old Jan 18, 2009 | 06:53 AM
Looks great ,bet it goes well
Old Jan 18, 2009 | 08:49 AM
Mr.T's Avatar
Mr.T
Nice turbo. What turbo is it?
Old Jan 18, 2009 | 08:44 PM
fez016's Avatar
fez016
Glenny Boy Nice work mate i bet it goes like fook.
Twins Looks great ,bet it goes well
thanks guys i really hope it does go well i am aiming for 300bhp but engine is new so i ll have to run it in before starting to set it up for power. aiming for 27psi
JeroentjeRS Nice turbo. What turbo is it?
hey!!! turbo is a t3/t4 with a .48 compressor housing. hows your project going?
Old Jan 22, 2009 | 03:05 PM
fez016's Avatar
fez016
Got her started up today for the first time it sound the nuts!!!! Everything sound fine. now its just a matter of connecting radiator and intercooler and off for a test drive.
Old Jan 22, 2009 | 03:18 PM
Luca's Avatar
Luca
Lukesville
Looking awesome mate
Old Jan 22, 2009 | 04:14 PM
fez016's Avatar
fez016
cheers
Old Jan 22, 2009 | 04:27 PM
Mr.T's Avatar
Mr.T
Dead slow really Thanks for asking
Old Jan 22, 2009 | 05:54 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
lookin gd mate
Old Jan 22, 2009 | 08:56 PM
Brian's Avatar
Brian
Brian
Old Jan 22, 2009 | 09:02 PM
little bram's Avatar
little bram
look's realy good mate top job. did you get std comp pistions
Old Jan 23, 2009 | 06:17 PM
fez016's Avatar
fez016
yes mate standard compression. Thanks for the feedback
Old Feb 6, 2009 | 06:37 PM
fez016's Avatar
fez016
some bad news looks like the pressure release valve in the oil pump is stuck and my engine is running 100psi of oil pressure. Tried to remove the relieve valve plug but the head of the bolt distorted, so now it means sump and oil pump have to go out again
Old Feb 17, 2009 | 09:40 AM
fez016's Avatar
fez016
here are some updates :
oil pump was removed and pressure release valve checked
intercooler fitted
bumper has been modified and re sprayed so it can take the intercooler
car is finally ready doin its running in - really powerfull at 12 psi of boost cannot wait to set it up properly !!!
Old Feb 17, 2009 | 09:54 AM
stembo21's Avatar
stembo21
well done bet it goes like fook now
Old Feb 17, 2009 | 09:55 AM
SteveH's Avatar
SteveH
Nice one mate, working well on that!
Old Feb 18, 2009 | 05:14 PM
wess-rs's Avatar
wess-rs
what kind of intercooler is it mate..??
Looks very good!!
Any specs..??
Old Feb 18, 2009 | 06:48 PM
Mr.T's Avatar
Mr.T
Nice job there. How did you turned the inlet pipe? i am getting the same one. And going to use the same type of ic as you.
Old Feb 19, 2009 | 07:18 PM
malcs-escort-cos's Avatar
malcs-escort-cos
great job mate looks awesome
Old Feb 23, 2009 | 04:34 PM
fez016's Avatar
fez016
wess-rs what kind of intercooler is it mate..??
Looks very good!!
Any specs..??
intercooler was bought through ebay from germany. As to specs its got:
beige injectors, stg2 chip, kent cam, steel rods, forged pistons, balanced bottom end, lsd, t3/4 turbo thats mainly it.
Mr.T Nice job there. How did you turned the inlet pipe? i am getting the same one. And going to use the same type of ic as you.
he he cut and tig weld but thats gonna change as well as im looking for a new plenum chamber.
Thanks for the comments
Old Apr 29, 2009 | 08:34 PM
fez016's Avatar
fez016
running in over and boost upped to 15psi. Fitted rollcage and front semi slick tires. Tried it against my friends EVO 10 - killed it on straights and kept up with it in corners. Next projects - aftermarket ecu and new plenum. Will post some pics of the cage as soon as i find my camera cable
Old Apr 29, 2009 | 08:52 PM
Robs Frst's Avatar
Robs Frst
Looking good
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
turbobill
Aug 1, 2015 08:55 PM
