efi running problems
Old Jan 10, 2009 | 03:27 PM
paul66 turbo's Avatar
paul66 turbo
Default efi running problems
finaly got my series 2 up and running efi, but got a problem with the map sensor its ofac ecu and map sensor the car starts and runs without the map sensor connected but when i plug it in the car miss fires and stalls it seams as if its running very rich with it connected???
Old Jan 10, 2009 | 03:53 PM
Šhatter Box's Avatar
Šhatter Box
map sensor faulty have you got the right one on??
Old Jan 10, 2009 | 04:36 PM
paul66 turbo
Default efi
im sure its the correct 1 do you no the part number for a ofac map sensor?? could be faulty. i havent cut the wire to the edis yet could this cause the fault?
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 19, 2015 11:46 AM
marky_g
Aug 17, 2015 12:21 PM
Zoggon
Aug 10, 2015 10:39 AM
