Mountune engine for sale !
So we have for sale here a clubman Mountune engine, built to high-specs:
Set #3: Big turbo escort inlet manifold with sensors, fuel rail with aeroquip fitting and 1 braided hose included with fuel regulator, 4x grey injectors, Mountune throttle body with Mountune ALS valve (can split that 3rd set in 3 parts : Mountune throttle body with Mountune valve (250£), 4x grey injectors with fuel rail/fuel reg and aeroquip hose (180£), Mountune ported inlet with air sensor (75£))
SOLD ! 200 block rebored to 91.325mm with 6 Mountune long studs, Mountune 8.6:1 CR pistons with rings and rods, crank to suit the block/pistons, block complete including bearings, crank pulley, water pump, distributor, complete oil system (oil pump and lines)
SOLD ! Mountune ported head with Mountune cams, Mountune pulleys, isky valve springs on inlet side
SOLD ! Big wing sump with extra welding on the diff mounts and aeroquip fittings for wrc breather system, Mountune sump baffle to suit the big wing sump
SOLD ! WRC breather system with braided hoses and aeroquip fittings
All in perfect working condition of course (more details below in the 7th post) !
Engine loom, ECU, turbo have been sold already !
I added few pictures, but any quote on the engine parts ? Engine is still closed, but if anyone makes a good offer for it (everything listed there, including a complete manifold with 4 grey injectors, and sensors) I won't open it
For prices I have an idea, but really unsure, so its why I am asking how much do these parts usually sell for. Well not a lot of Mountune parts are sold "usually" but still
I have updated the first post, here is how the parts will be available, I won't split them in more, serious offers welcome. Postage will be at buyer's cost, although I can bring the parts to Ford Fair for free if not in a hurry.
The complete engine has been mapped by Harvey Gibbs (SCS) and gave 300bhp@5000rpm and 423lb/ft of torque with 34mm restrictor and SP98 fuel.
More pictures will come next weekend when I will open it as it is still in 1 piece.
Set number 3 is now sold !
I don't want a lot for the parts, and I take english pounds. With the actual exchange rate of the Pound (with Swiss francs) I think that can't be hidden
which counts?
once the head is including all ancilliary stuff like inlet manifold and so
once without
please give me a price for the head, without inlet and greys and so.
thanks
once without
thanks
rog
Sep 4, 2015 12:10 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
