Smoke when I back off?
Old Jan 9, 2009 | 09:07 AM
adam.d's Avatar
adam.d
Default Smoke when I back off?
Valve stem seals or turbo? what do you all think?
Quite smokey on start up on a morning, but clears when warmed up a bit. No smoke when accelerating, but when I back off I get a little cloud?
Old Jan 9, 2009 | 09:14 AM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
sounds like both mate!
Old Jan 9, 2009 | 09:22 AM
turbo.jon's Avatar
turbo.jon
sounds like turbo to me
Old Jan 9, 2009 | 09:27 AM
adam.d's Avatar
adam.d
Bastard! double whammy!
The head and the turbo have both only done 700 miles tho
Old Jan 9, 2009 | 10:03 AM
RSTurboSI's Avatar
RSTurboSI
agreed there.
mine used todo that untill i got a new engine rebuilt and tunned up.
Old Jan 9, 2009 | 10:08 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
700 miles since what???
If the turbo was a rebuild or new it could be covered by the warranty.
Old Jan 9, 2009 | 01:09 PM
wilky's Avatar
wilky
normally the turbo would not smoke straightaway on start up as the exhaust housing is not hot enought to burn the oil leaking in the exhaust housing,but does sound like seal's when you let off and it smok's
Old Jan 9, 2009 | 02:00 PM
adam.d's Avatar
adam.d
Been down to see my mate, he also said looks like both
Stem seals will be done 1st as there the cheapest then if I need a new turbo I'll just have to save up for a stage 3
Old Jan 9, 2009 | 02:40 PM
mercury grey minter's Avatar
mercury grey minter
Deffo turbo.Mine did the same.Stem seals are gone when you pull away from standstill and you leave a cloud of smoke behind.
Old Jan 9, 2009 | 03:29 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah does sound like both!
Old Jan 9, 2009 | 04:49 PM
rstdave's Avatar
rstdave
I would say turbo too, had enough experience of them going to know by now lol, sounds exactly like what happened when i bought a 2nd hand turbo that had apparently only done 1000 miles pmsl...would never buy a 2nd hand one again unless i knew where it came from.
Old Jan 9, 2009 | 05:01 PM
adam.d's Avatar
adam.d
That's the thing with mine tho, everything under the bonnet has only done 700 miles max!!!
I've ordered some stem seals so these will be done soon, anyone know how long they take to change?
Old Jan 9, 2009 | 05:44 PM
neilrev's Avatar
neilrev
should only take an hour or two mate.
Old Jan 10, 2009 | 09:31 AM
B1G_RST's Avatar
B1G_RST
youl need tht wee fancy stem tool, i got mines of ebay shit hot little tool like, try the stem seals first bud,,, have you considerd the rings?
Rstar_man
143
Jul 20, 2020 11:16 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Adam-M
22
Aug 10, 2015 10:46 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
