Easy mate, Starter off, exhaust disconnected, sump off, bottom pulley off, oil pickup off, pump off!
Might have to drop the engine slightly on the pump side.
Yeah I did mine using a lift so was really easy!
The pulley comes off without dropping the engine but i couldnt quite squeeze me new pump back up onto the crank.
bit of a mission getting the pump on to the crank, but the hardest bit comes when you refit the sump!
Yeah that can be a pain!
Easiest way i have found is to superglue the new gasket to the bottom of the block then refit the sump. I've had 100% success with this method no leaks!
