actuator rattle
just fitted it mate, whats preload?
i adjusted the rod length to run 12psi
if the rod isnt tight enough(preload) it will rattle,
tbh at 12psi you dont want a -31, as you cant run any preload or it will make to much boost.
normally, we aim to run half a hole of preload...ie you need to PULL the actuator rod half the hole to get it to slip over the wastegate arm.
at half a hole preload how much boost will it make?
Fudgey
Sep 17, 2015 01:06 PM
