my cars suffering with cold, plz presribe remedy
Old Feb 19, 2004 | 03:22 AM
Default my cars suffering with cold, plz presribe remedy
Hey guys, this question has probably been asked a hundred times before but i still dont know how to fix her.
Ive got a 2wd cossy running at about 330bhp, my problem is that it just wont idle when the engine is cold, is there a sensor or something that controls these sort of things that may be faulty or knackered. The problem is getting to be a pain in the bum as i usually run the engine for about 5 minutes before going anywhere and i am having to wedge the crook-lock onto the exellerator just to warm the engine.
Any help greatly appreciated.
Old Feb 19, 2004 | 03:24 AM
Forgot to mention that i have recently changed the Air Temp Sensor and the Engine Coolant Sensor without any notable success.
Thanx again
Old Feb 19, 2004 | 05:59 AM
Stu @ M Developments's Avatar
PassionFords Creator
Has the idle speed control valve and its wiring been checked?
Old Feb 19, 2004 | 11:15 AM
Hi Stu, i have not done anything to the ISCV, but now you mention it i will take it off and see if its dirty and spray a bit of carb cleaner around it. Do you just have to attach a multi-meter to the connections to check the wiring or is it a bit more complicated than that?
Many thanks
Old Feb 19, 2004 | 11:28 AM
Pin them out back to ecu.
You may find the valve is just knackered mate. If it rattles, its not good.
Old Feb 19, 2004 | 02:45 PM
I think i may have sorted it mate, it took the ISCV of and gave it a good cleaning and noticed the connector was a bit dirty so cleaned that as well and BINGO the engine started running at 850 rpm again when all was put back as it is supposed to be. So big thanks for pointing me in the right direction.
Shows & Track Days
Aug 26, 2015 05:11 AM
Bailes1992
Aug 16, 2015 07:14 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
Archiejay
Aug 12, 2015 12:07 PM
