Cosworth parts, old post
- Escos rear std 7" diff. good condition,
£158 posted, £145 collected
- Escos front std diff, 70k miles,
£80 posted, £67 collected
- 4wd Exhaust manifold. no leaks etc.
£75 delivered, £65 collected
- 4x4 gearbox, with no transfere box or gear cradle, come out of a 4x4 saph on 70k miles.
£120 collected, for extra cost i can build it to be complete again, if you brought your box for the parts.
- 2wd high pressure/flow oil pump From Burton power, and pickup, 5k miles since new. no internal wear or marks. been used in 2wd and 4wd setups before.
£82 posted, £70 collected
- RS500 inlet.
Comes complete with rails, reg, plenum,throttle, elbow, inlet,. and a stainless steel throttle cable bracket.
The whole things been ported and flowed to a touring car spec head.
The elbow has been mod'd years ago by Julian Godfrey, to even flow to cylinder 1 and 4
£1170 posted.
- 'Ford' conrod bolts, fitted for 500 running miles before respec, still in box
£30
- Escos 'Ford' TCA's, poly bushed, used but in good working order 1 needs a new boot, £55 collected
- 4wd engine mount arms, £25 posted, £15 collected
- 4wd cossie intercooler (standard item), pressure tested to 38psi with no leaks at all. £50,
if any questions please pm, call or text me on 07855 377423.
Thanks Danny
- RS500 inlet.
£1170 posted.
£30
Thanks Danny
Aug 14, 2015 07:29 AM
