rs turbo holds back afta 65mph+ ??
Old Jan 3, 2009 | 02:49 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default rs turbo holds back afta 65mph+ ??
i swapped my turbo's ova 2day, using the same actuator, and it feels like its running 5psi an i usually run 16psi, 2cd 3rd 4th 5th hardly hav any torque/boost, cud my actuator b at fault??
Old Jan 3, 2009 | 02:54 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
did you unscrew the threeded bit at all? was it the same turbo you fitted. are you still useing the amal valve
Old Jan 3, 2009 | 03:08 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
If the turbo is the same, and you installed the actuator with identical pre-load, then it should be similar.. otherwise the turbo is fucked or you have a serious air leak.
All roads tend to lead to user error.
Old Jan 3, 2009 | 05:01 PM
TuRbO-CaB-LaD
its a diffrent turbo fitted, but i took my actuator + bleedvalve off my previous turbo an used it on the replacement , not sure wat u mean by (did you unscrew the threeded bit at all?) iv looked 4 air leaks cant find any
Old Jan 3, 2009 | 08:44 PM
B1G_RST's Avatar
B1G_RST
the bar on the act can be screwed in out to set the boost, if you alterd that then this explains your problemm
Old Jan 4, 2009 | 01:25 PM
TuRbO-CaB-LaD
ok i changed the actuator an its boostin ok now, only thing buggin me is the dumpvalve is really quiet wen it dumps even on heavy load at 6000rpm? the dumpvalve was workin ok on my shagged turbo before i changed it? any idea's?
Old Jan 4, 2009 | 01:34 PM
cossieDavedree's Avatar
cossieDavedree
get rid of the d/valve,, they're pointless on an rs turbo
Old Jan 4, 2009 | 02:52 PM
TuRbO-CaB-LaD
ye i no there pointless, but my gf likes driving it wiv the dumpvalve lol,any idea's?
Old Jan 4, 2009 | 03:06 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Dump her
Old Jan 4, 2009 | 04:21 PM
TuRbO-CaB-LaD
lool
EoinXR3
Sep 7, 2015 05:44 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Bailes1992
Aug 16, 2015 07:14 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
