Crossover pipe
Old Jan 1, 2009 | 07:07 PM
RSTurboSI's Avatar
RSTurboSI
Default Crossover pipe
will a FRST cross over pipe fit a escort?
Old Jan 1, 2009 | 07:58 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
if ya got 90 spec cover couldnt see why not
Old Jan 1, 2009 | 08:02 PM
RSandy's Avatar
RSandy
yeah would need the 90spec rocker cover for the bolts to line up, plus im unsure how its affected by use with an mfi inlet n TB as opposed to an efi inlet n TB, which may make it shorter n therefore pull the top boost hose about a bit. could be wrong though...
Old Jan 1, 2009 | 08:04 PM
RSmark84's Avatar
RSmark84
as said, 90 spec rocker(cam) cover it'll fit straight on, but not sure on the other end as the hoses are different angles on either RS.
best of getting an auto specialists one if you wanted it for the 'turbo' logo.........?
Old Jan 1, 2009 | 08:27 PM
orion_crazy_carl
orion=mini saff
guessing u would idealy need a fezzie top boost hose?
Old Jan 1, 2009 | 08:37 PM
RSandy's Avatar
RSandy
i would have thought so, although does the frst intercooler sit in exact same position as the s2?
im thinkin whichever way u go, there might be a hose slightly forced out of shape lol
Old Jan 1, 2009 | 08:43 PM
RSTurboSI's Avatar
RSTurboSI
maybe give it a miss,
my only reasson is i dont want a knock off chrome turbo crossover pipe. i want a Gen Ford crossover and the FRST has the turbo onit, wanna keep the car looking clean
If it will cause more problems then maybe i should leave my standard one on
Old Jan 1, 2009 | 08:48 PM
RSandy's Avatar
RSandy
personally i hate the 'turbo' crossover pipes, looks like its done in large raised lettering for the sight impaired, who also apparently cant divert their eyes a few inches closer to the slam panel to notice the turbo sat there for the world to see
Old Jan 1, 2009 | 08:59 PM
RSTurboSI's Avatar
RSTurboSI
you have a point
Old Jan 1, 2009 | 10:22 PM
orionmojo's Avatar
orionmojo
or infact that theres a crossover pipe there at all
Old Jan 2, 2009 | 03:47 PM
Gadget's Avatar
Gadget
Spanner monkey
Yes, it fits but the hose to the frst crosspipe fits over the hose to the escort throttle body so you need a small section on the throttle body, then slide the larger fiesta one over it! Then, at the other end, use a fiesta turbo intercooler hose, or shorten the cross pipe for the escort one!, but then you dont have a boss for the act sensor AND you'll have a pipe that needs blanking off by the throttle cable bracket!
Old Jan 2, 2009 | 03:51 PM
orion_crazy_carl
orion=mini saff
where would ya put the air temp sender tho?
Cosnada
Jan 7, 2016 05:30 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mpilk
Sep 27, 2015 09:21 AM
