ariel removal
Hi guys whats the best way to remove an unwanted ariel hole in the roof of a saff as someone has kindly drilled a hole for one and i want it gone as going to have a respray soon ?
take the aerial out, dependant on the size of hole left you could either put a couple of tacks of weld in it or cut out a disc of metal the size of the hole and weld it in Then smooth the weld and fill from above then prime it. keep the moisture away though as primer is porous
best way is to weld it up which means roof lining out and a roof repaint
Or you could find a rubber blanking grommet but make sure it fits tight and i'd put some black waxoyl around the edge first then push it in wipe excess off
Depends on what u what cheap or expensive
Paul
Paul
Don't forget to etch pime under and and seal it with pait or brush on sealer
Paul
DON'T FORGET TO COVER ALL GLASS AND INTERIOR !!!
right then easiest way make the hole and the plate oval shoped bit make the plate slightly bigger
then tack weld a nail to the middle of the plait then use the nail to get it inside the hole then pull it upp to cover then weld from the outside i done dicko frome here,s car this way
Orion_Gav
Sep 29, 2015 04:50 PM
