focus 1.6 zetec s under fueling and bad idle
Old Dec 29, 2008 | 07:25 PM
n1cky(cf23)'s Avatar
n1cky(cf23)
Default focus 1.6 zetec s under fueling and bad idle
hi need some help my focus idles at around 700-750 once it comes off warm up,replaceced plugs,air filter,checked leads and coil all ok. no signs of an air leak neither! Put on gas machine and co aorund 15% with the Hc`s around 2-5! any help would b good cheers nick.
Old Dec 29, 2008 | 07:33 PM
RichieST's Avatar
RichieST
idle speed sounds about right....
Old Dec 29, 2008 | 07:43 PM
n1cky(cf23)
its got a flat spot from under fueling but when i come to a stop it gets realy lumpy likes its going to cut out its a real head scratcher!
Old Dec 29, 2008 | 07:53 PM
RichieST's Avatar
RichieST
How did you check the coil pack? I would suggest this is at fault, very common for these to fail giving the symptoms you are describing!
Old Dec 29, 2008 | 07:54 PM
RichieST's Avatar
RichieST
Either that or idle control valve, remove, clean and oil, if that doesnt fix it then replace
Old Dec 29, 2008 | 07:58 PM
n1cky(cf23)
i done a resitance check all was ok acording to autodata. i had a feeling it could be that i`ve checked everything other than! thanks for the help let you know how it goes.
JoeyBoyden
Jan 4, 2024 02:36 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
