how to do? fwd to awd
Old Dec 28, 2008 | 09:51 PM
Herfli's Avatar
Herfli
Rally, rally, rally...
Default how to do? fwd to awd
Hy!
Sorry to my bad english, i'm hungarian.
I have an 1.8 Zetec project to my mk3 escort, and i thinking about the AWD system... what are you offer to me? rs2000 4x4 AWD system or Cossie or any ideas (sierra 4x4)? my engine is the original cross mounted... sorry to my bad english...
Old Jan 1, 2009 | 10:52 AM
NUTS RuS's Avatar
NUTS RuS
Hello Herfli
Most people take the easy option and take the floor from a 4x4 Sierra and weld it into the Mk3 Escort shell.
You can then use the Sierra engine / gearbox and suspension to get your 4x4 AWD
Old Jan 1, 2009 | 11:44 AM
Herfli's Avatar
Herfli
Originally Posted by NUTS RuS
Hello Herfli
Can I use the zetec engine, which is ~ 170 BHP now, and it was a lot of money... and i love it!! If we rotate the engine to longitudal mode and we make an other custom exhaust system? The Sierra 4x4 gearbox fit to the Zetec (Silver Top) engine?
Old Jan 1, 2009 | 11:49 AM
Herfli's Avatar
Herfli
We have an other idea... just some words: Audi 80 Quattro gearbox, sierra RWD rear axle, Lancia Delta HF Integrale drivetrain... but the idea of you is take it easy.
Old Jan 1, 2009 | 11:50 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
170bhp from a 1.8 zetec on a standard inlet manifold?
Old Jan 1, 2009 | 12:01 PM
Herfli's Avatar
Herfli
originaly it is the 130 bhp engine, and for example i have compression 19 so i spent a lot of money.
engine:
custom verner pulleys (not in the photo),
ported, polished head (5mm+),
ported, polished inlet manifold, custom exhaust and inlet cam,
mondeo throttle body,
mondeo 2.0 injectors,
1.5mm- from the head under,
custom exhaust system,
etc... fully rebuilt.
for example:
mitsu oil cooler, s1 rs turbo sperr, the brake system fornt rs2000, rear xr3i (front disc), hydraulic handbrake, etc...
Old Jan 1, 2009 | 12:02 PM
NUTS RuS's Avatar
NUTS RuS
You can use your engine and turn it round - they are used like that in some kit cars (Caterham's etc) But it would only be RWD
Old Jan 1, 2009 | 12:03 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
19:1 compression ratio?
Old Jan 1, 2009 | 12:11 PM
Herfli's Avatar
Herfli
why yust RWD?
Old Jan 1, 2009 | 12:13 PM
Herfli's Avatar
Herfli
yes! i'll take a picture later.
the NGK Laser Platinum sparks have a little warmy
Old Jan 1, 2009 | 12:18 PM
NUTS RuS's Avatar
NUTS RuS
The bell housing for the gearbox only fits a RWD gearbox as no output to front wheels is needed on kit cars.
4x4 Sierra is easiest way to start
Old Jan 1, 2009 | 12:21 PM
Herfli's Avatar
Herfli
http://www.filkornauto.com/sport.htm
It is a hungarian Ford Service and Rally Team...
They have an mk3 Escort 4x4, and not the sierra 4x4 drivetrain i think.
Its is a 2.0 Zetec Turbo, with cross mounting engine, but still AWD...
Old Jan 1, 2009 | 12:22 PM
Herfli's Avatar
Herfli
i like the sierra 4x4 idea...
Old Jan 1, 2009 | 12:36 PM
Phil2002's Avatar
Phil2002
it uses an mtx75 box and transfer box from an escort rs2000 by the looks of it.
i have a mondeo(very similar to rs2000) 4x4 gearbox, transfer box, prop shaft, fuel tank and drivers side front drive sharft (the important one) for sale if your interested i'll even ship to hungary if your willing to pay the shipping?
cheers,
Phil
Old Jan 1, 2009 | 12:37 PM
COLEYST200's Avatar
COLEYST200
THIS is on there web site
Old Jan 1, 2009 | 12:41 PM
Herfli's Avatar
Herfli
yes i know... its is all custom made... i contact they...
Old Jan 1, 2009 | 12:45 PM
Phil2002's Avatar
Phil2002
it may be custom made but it's a copy of the escort rs 2000 transfer box.
Old Jan 1, 2009 | 02:19 PM
NUTS RuS's Avatar
NUTS RuS
As said RS2000 4x4
Poor heavy weight over front wheels.
Sierra 4x4 is easier
Old Jan 1, 2009 | 06:40 PM
Herfli's Avatar
Herfli
i think, we are get it wrong each other
not the ratio (fuel/air) 19
in the cylinder 19 the comp...
Old Jan 1, 2009 | 06:49 PM
Herfli's Avatar
Herfli
As said RS2000 4x4
yeah i know... my friend can weld an dohc (sierra 4x4) crankcase to the zetec, so it can be solvable...
so i think i rotate the zetec, i put under the dohc crankcase and a complette sierra 4x4 drivetrain, gearbox, etc...
now, i've got offer an sierra 4x4. so i can buy the sierra 4x4 now 'bout 200-300 USD (conversion of HUF).
Old Jan 1, 2009 | 06:56 PM
Herfli's Avatar
Herfli
the next project next to the AWD system, it is the turbo...
its need turbo, the much power, reason the AWD system.
i waiting any ideas of the turbo both.
Old Jan 4, 2009 | 10:18 PM
Herfli's Avatar
Herfli
hmmm, i have an other idea... Zetec Turbo RWD!!! how can i start it?
Old Jan 5, 2009 | 12:11 AM
JMS Erst's Avatar
JMS Erst
if you are looking for rwd? the t9 gearbox from a sierra saphire 1.8cvh should bolt up to your zetec, you could probably use alot of those parts, axles, gearbox tunnel etc.not too sure how much abuse it will take before i was thinking of a similar conversion to my mk4 rs turbo.. you could still keep the engine non turbo and it would still be pretty quick. if you want turbo.. well i`d personally lower the cr myself, but there is so many options/opinions of tuning for the zetec. i`d like to see the progress if you find a way to do it
good luck with it
Old Jan 5, 2009 | 09:08 AM
vibrating_cake's Avatar
vibrating_cake
why would you need AWD at ONLY 170bhp??
nothing wrong with RWD! and a LOT easier!
and it only being a small engine i doubt it has enough torque to NEED AWD, unless its gonna be raced off-road loads i dont see the point on the extra expense?
RWD zetec is easy =)
Old Jan 5, 2009 | 01:42 PM
JMS Erst's Avatar
JMS Erst
nice looking conversion you have there i agree i think rwd would be alot easier.... what gearbox is it you are using in your capri to bolt up to the zetec just out of curiosity?
Old Jan 5, 2009 | 02:16 PM
Herfli's Avatar
Herfli
hm, i like the rwd idea.
you'r right, there is no much power to 4WD, but RWD... yeahhh...
what rear axle do you offer me? a simpli sierra?
i have mondeo injectors, but i have 2 Dellorto DHLA-40 too... injector or carb? the carb sound... ahhh...
Old Jan 6, 2009 | 08:48 AM
vibrating_cake
its the standard type 9 gearbox, bolts streight up they are on early sierras and most 5speed 80's fords
Old Jan 6, 2009 | 09:29 AM
RSTurboSI's Avatar
RSTurboSI
Just stick a coswroth engine in and be done with....
Old Jun 22, 2009 | 08:31 PM
Herfli's Avatar
Herfli
if i put the dellorto's, how to do the ignition... because ignition needs computer, and modul... the injector is much easier, i think, but i want put in the carbs...
the car is now injector, and go fast... but i want to change it to carb...
Chas
Sep 21, 2015 08:57 PM
Rick
Jan 20, 2005 09:39 PM
mark_J
89
Jan 12, 2005 10:42 PM
Kev.H
Nov 12, 2004 04:06 PM
Thrush
13
Jun 26, 2004 07:27 PM
