Lowering Help!!!!!!!!!!
Old Nov 20, 2004 | 09:30 PM
mitchrs's Avatar
mitchrs
Default Lowering Help!!!!!!!!!!
ok, just lowered my series 2 50mm...... what a fookin mistake that was, exhaust centre pipe scrapes on every bump, my drive, every little bump in the bloody road.
im on standard rims, wats a good hieght to go for??
do i put standard springs back in or do i just put 17s on and try and raise it up a bit??
any help, greatly appreciated.
cheeRS lads.
Old Nov 20, 2004 | 09:32 PM
SS1's Avatar
SS1
cut out the middle box on the system
worked 4 me
Old Nov 21, 2004 | 12:41 AM
escort1989uk's Avatar
escort1989uk
sell springs and get a 30mm drop
Old Nov 21, 2004 | 11:30 AM
bassboy's Avatar
bassboy
i rekon 30mm m8 as the ride height is still nice and comfy yet sporty enough for fast road driving...and the car looks sweet as with that drop...got a pic somewhere...
here ya go
and heres mine with a -45mm drop on the front only with 17s
HTH
bassboy
Old Nov 21, 2004 | 02:58 PM
mitchrs's Avatar
mitchrs
Bad Company: haven got a centre box fella, mongoose full system with 3 inch pipe straight through??!!
Bass Boy: Black rs looks well mint , likin it!! does the red s2 rub/scrape at all??
cheers all 4 help!!
Old Nov 21, 2004 | 09:31 PM
adamS2RST's Avatar
adamS2RST
Far too low imo, I have gone 25 on 17'S and that is about tight imo
Old Nov 21, 2004 | 10:34 PM
bassboy's Avatar
bassboy
mitch - red one does scrape with the rims on the arches on the back a touch when alot of people are in the car or when cornering VERY hard apart from that its fine...or if your talking about the exhaust, nope its fine generally but i get the odd few bumps here and here where it does scrape...however i am running a 3" bore exhaust as well
bassboy
Old Nov 22, 2004 | 01:26 PM
vx220's Avatar
vx220
don't know if changing to 17s will help. try this...
www.tyresave.co.uk/tyresize.html
going from 195/50/15 to 205/40/17 is only gonna give you 20mm extra diameter, so 10mm increase in ride height! that may be enough, i don't know. i suppose you'll lose some of the sidewall flex as well, that might help a bit!
Old Nov 22, 2004 | 01:52 PM
KSA-Cossie's Avatar
KSA-Cossie
Any more than - 25mm tends to give you understeer.
Old Nov 22, 2004 | 08:17 PM
odn198's Avatar
odn198
ksa74f/231bhp, your car is too slow to have understeer
Old Nov 22, 2004 | 08:38 PM
bassboy's Avatar
bassboy
kev - will adjustable TCA's solve the understeer?
bassboy
Old Nov 22, 2004 | 09:04 PM
Krazy Kim's Avatar
Krazy Kim
I've got mine at 30mm and it's perfect but i do have a stainless steel custom made exhaust which is set higher up under the car
Old Nov 22, 2004 | 09:59 PM
AJC's Avatar
AJC
i have 40mm drop on the S1 and when i put my 17s with 205/40s it scraped on every arch with 3 people in the car, going to change it for 25mm i think,
who does a 25mm spring please any one?
cheers
Old Nov 23, 2004 | 07:49 PM
mitchrs's Avatar
mitchrs
ok lads and lady! fanx 4 all help, anyhow solved it now....just got a local garage to weld a new exhaust hanger and clip at either end of the pipe to the underside of my car!!
works lovely, no more scraping!
Wahay!!
Old Nov 23, 2004 | 07:52 PM
mitchrs's Avatar
mitchrs
series1ajc: PI do a -25mm kit for the series 1.
phone burton power . 0208 554 2281
Old Nov 23, 2004 | 09:07 PM
Alan s1's Avatar
Alan s1
I had burton own one on my old saff and there the dogs bollock in my eyes i got to get com front spring for my s1 as the front is very low
Old Nov 24, 2004 | 06:20 PM
KSA-Cossie's Avatar
KSA-Cossie
Was too fast for your old turbo and is way too fast for your 316 rustbucket.
Old Nov 24, 2004 | 06:21 PM
KSA-Cossie's Avatar
KSA-Cossie
bassboy
They would certainly give you more scope to make it handle better.
Old Nov 25, 2004 | 10:02 AM
RS-adam's Avatar
RS-adam
got my S2 lowered 40mm on 205/40-17 and I have NO problems.. not even with 4 peps in it... I really have to push it hard throu the corners to get ot to scrabe in the arches.. And I have 2.5 goose on it, dosent scrabe either...
Old Nov 25, 2004 | 03:35 PM
odn198's Avatar
odn198
ksa74f/231bhp, at least mine is all one car. not two welded into one l.o.l.
Old Nov 27, 2004 | 10:42 AM
KSA-Cossie's Avatar
KSA-Cossie
Ok you win seeing as your mums ass is nice and tight.
Old Nov 27, 2004 | 03:11 PM
odn198's Avatar
odn198
ksa74f/231bhp, are you getting bored with your mum that you have to go to mine
Old Nov 27, 2004 | 05:03 PM
KSA-Cossie's Avatar
KSA-Cossie
Nah only cos you're mum can suck an elephant through a hose.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
roomey
Sep 19, 2015 08:40 AM
