help puma clutch
hi there iv got a 1.7 puma and the clutch is slipping i was wondering how hard it is to change .iv had some big quotes to have it replaced so was just wondering how hard it would be to change it myself any help welcome
You can change it yourself as long as your capable of removing the gearbox and bleeding the system. Its relatively simple to change the clutch
the pain in the arse bit is removing gearbox
especially if your doing it yourself!!!
its the 1.7 puma well iv dun quite a few escort rs turbo clutches and one cosworth clutch .is the box easy enough to drop down and out
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
