xr2i electrical faults please help :(
Old Dec 25, 2008 | 12:59 PM
thom4s-1's Avatar
thom4s-1
Unhappy xr2i electrical faults please help :(
Hi all recently purchased an xr2i it has the following problems: interior light doesnt work (changed bulb still no luck) Passenger side window doesnt work ( i have removed door card and can feel a click on the motor when i press the button) Boot release doesnt work, boot interior lights not working either. Anyone got any idea's what i can do ive checked all the fuses in the compartment next to drivers right knee and there all ok, cheers Tom
Old Dec 25, 2008 | 01:24 PM
martysmartie's Avatar
martysmartie
Does interior light work when switched on by switch? I'm guessing you mean it does not work when door is opened in which case may be a door switch. Have you tried opening the passenger door and see if it works?
Failing that remove bulb again and with a multimeter and door open or light switch on make sure you are getting 12V to the light socket, if not this means there is a problem further back, you say you have checked the fuse and so may be a connection problem between fuse and light.
As to the electric window problem if you can hear it clicking then this means the power supply is fine, so I would say either a motor or regulator problem but check to make sure the window is just not jammed.
I think most likely it will be a regulator problem. In which case a new one will be needed.
Remote boot release sounds like it has no power connection so just go over and check connections.
Check boot light in the same method I have described above for interior light.
Best of luck with it,
Martin.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Kam B
Sep 24, 2015 10:40 AM
Andypandy260
Sep 23, 2015 10:28 PM
