Various cosworth parts
Old Dec 22, 2008 | 05:50 PM
Steve Escos's Avatar
Steve Escos
Default Various cosworth parts
As title will be clearing space so i have the following for sale:
4x4 front anti roll bar £10
4x4 Drivers side hub needs a wheel bearing (supplied) £50
Complete set of front and back 3 dr brakes with drilled and grooved discs, backs look nearly new and fronts were refurbed recently £200
Spec R Small turbo cambelt cover £85
Group A coil brand new £20
Twin ignition amp bracket in black £30
Escos nomad a pillar pod for 52mm gauge (as new) £35
Rs 4 spoke wheel, ok condition but no boss £50
Pace turbo cooler £50 SOLD
2wd stainless exhaust no front pipe / tatty £30
T34 turbo needs a rebuild, 48 housing £150
Hoses - lots from standard to silicone -offers
2wd gearbox £250 SOLD
2wd inlet £15 each ( i have 2) BOTH SOLD
2wd Exhaust manifold (both parts) £50
Complete 2wd engine - needs rings offers
2wd loom, not the best £25
2wd loom £50
L1 ecu - untested £30
Set of dark green injectors £100 SOLD
L6 ecu with stage 3 chip £60 SOLD
2wd turbo heatshield, cracked lower down - £25 SOLD
Will add more parts as i go.
I can be contacted on 07725238098.
Regards Steve
Old Dec 22, 2008 | 06:14 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
will take both 2wd inlets
Old Dec 22, 2008 | 06:55 PM
sortedsaff's Avatar
sortedsaff
more info and the engine please mate and a rough price please .
pm if you like
Old Dec 22, 2008 | 07:00 PM
Steve Escos
Engine may be sold however it is a 205 block mileage aprox 86 thou. Will be taking head off to check bores and head thickness. Been offered a grand for the engine so far.
Steve Escos
Send me a pm to confirm with delivery address and will work out postage.
Regards Steve
Old Dec 22, 2008 | 07:16 PM
The Youth.'s Avatar
The Youth.
is the turbo just in need of bearings and seals or is there more serious damage?
will have it if it's not completely fubar
cheers,
steve
Old Dec 22, 2008 | 07:20 PM
Steve Escos
Lot of play in the shaft so not sure of condition really. Was going to split it apart but just haven't had time.
Old Dec 22, 2008 | 07:26 PM
The Youth.'s Avatar
The Youth.
steve has either of the turbines hit the housing?
should be fairly easy to see without stripping it
cheers
steve
Old Dec 22, 2008 | 07:29 PM
Steve Escos
Don't think so but will check tommorrow. Will put some pics up. Only thing i am aware of is that it has a machined front housing to allow a T3 hose to fit.
Old Dec 22, 2008 | 07:34 PM
The Youth.'s Avatar
The Youth.
cheers steve
steve
is there an echo in here lol
Old Dec 22, 2008 | 08:37 PM
thepintoman1's Avatar
thepintoman1
yhpm mate
Old Dec 23, 2008 | 04:00 PM
Char1ie's Avatar
Char1ie
Just wondering if you have a Sparco style alloy strut brace? Eccentric top mounts?
Thanks,
Charlie
Old Dec 23, 2008 | 05:32 PM
Steve Escos
Thanks,
Charlie
Sorry mate no.
Regards Steve
Old Jun 2, 2009 | 09:15 PM
rs2000STR's Avatar
rs2000STR
the engine is complete? How much is the block and head price?
Old Jun 2, 2009 | 09:52 PM
joe s's Avatar
joe s
What hoses do you have mate?
Old Jun 3, 2009 | 03:14 PM
Steve Escos
I have a selection of standard and samco blue hoses. What do you need?
SmudgerByName
52
Jul 28, 2016 06:14 PM
3dr cossie
11
Dec 21, 2015 03:38 PM
155lee
14
Aug 22, 2015 12:15 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
