Afr readings
Old Dec 22, 2008 | 08:31 AM
Bens2rs's Avatar
Bens2rs
Default Afr readings
Been told if you want to live map your car to get a safe reading of afr you need to put a lambda sensor on the downpipe, is this true or can you use lambda in tailpipe?would the readings be any different??
Old Dec 22, 2008 | 08:38 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It's better in the downpipe.. There's very little room for error then.
Old Dec 22, 2008 | 03:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Agreed better in the downpipe, but when your car is setup on the RR they use a WB lambda that goes up your exhaust so either will be fine as long as its good quality!
Old Dec 22, 2008 | 04:44 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Reading AFR from the tailpipe only really causes a problem a low speed because air may get into the exhaust and 'influence' the reading.
Also, any leaks in the exhaust will affect the reading too.
Theoretically, if the exhaust is 100% leak-free, then the difference between measuring from the tailpipe or downpipe is very marginal.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Iain Mac
Sep 30, 2015 09:39 PM
20/20 vision
Sep 29, 2015 11:27 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
