rs turbo boost
Old Dec 17, 2008 | 08:36 PM
dj3flow's Avatar
dj3flow
Question rs turbo boost
Hi i have a fiesta rs turb i have a 195 chip 701 injetors.
when i have the boost set at 10 psi it runs fine but when i go passed 10 psi it starts cuttin in an out of boost
the chip an injetors are bran new so i know they r ok
help needed thx
lee
ps dose ne 1 know what is a safe boost i can run on a 195 chip an 701 injetors
thx
Old Dec 17, 2008 | 09:56 PM
paceo's Avatar
paceo
help needed thx
lee
thx
i know the standard fiesta unchipped ecu will go to 10psi, anything after and overboost will set in.
word of warning, dont fuck around with your boost ok, you will be buying a new engine soon, take it to a tuners who will set it up correctly!
Old Dec 18, 2008 | 12:16 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
it sounds to me like the chip has worked its way loose from the back of the ecu, push it back in to the ecu firmly and put some tape to hold it in place.
Hope this helps (and solves the problem)
Old Dec 21, 2008 | 11:56 AM
rst in breaking's Avatar
rst in breaking
in regards to how much boost you can run is a matter of opinion, depending on how good or how ropey your engine is? on a good engine id personally be happy with 16psi of boost
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
gchristophi
Aug 31, 2015 10:36 PM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
Escortdriver1
Jul 31, 2015 02:36 PM
