Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
ZVH speedo readings
Old Dec 17, 2008 | 12:08 PM
drivin2jungle's Avatar
drivin2jungle
mk4RS1900ZVHTcombi
Exclamation ZVH speedo readings
hi, iv just bought an escort combi with a 1.8 ZVH but the speedo is very out. 20mph on the clock is about 30, 30 on the clock is about 40 and thats all i have worked out so far. is there a quick fix? im assuming that there is a sensor on the flywheel that wont match the dials but that is a pure guess!? also the rev limiter reads half what it should do. the old owner mentioned maybe fitting dials from an EFi instead of the MFi dials that are in there now??
also, any common problems associated with a 1.8 ZVH? just so i know what to be looking out for.
thanks for reading, sam
Old Dec 17, 2008 | 12:26 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It uses a cable.....
Old Dec 17, 2008 | 12:49 PM
RS 5tu's Avatar
RS 5tu
ZVH,CVH wont make a difference becouse it takes the speed from the gear box, Try a new cable.
Old Dec 17, 2008 | 02:05 PM
drivin2jungle
mk4RS1900ZVHTcombi
Exclamation ZVH speedo - forgive my ignorance
thanks for the replies but if it takes the readings from the 'box, that will be why it doesnt match up surely? its got a 1.8 zetec box which is (i guess) geared higher so could that be why its readings slow?
Old Dec 18, 2008 | 11:04 PM
RS 5tu's Avatar
RS 5tu
mk3 or 4 escort? you can not fit a zetec box in a mk4 iirc so you will have the same box as normal and same cable and same speedo.
Old Dec 19, 2008 | 09:08 AM
drivin2jungle
mk4RS1900ZVHTcombi
Exclamation ZVH speedo/rev counter
thanks for the reply again. as you may well tell, i am still learing! its a mk 4 combi so it musy have the standard 1.6 box in it. (i just thought it wouldnt match the zetec bottom end - obviously i am wrong. i will try the nu cable.
any ideas on the 'half-speed' rev counter though?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
Iain Mac
Sep 30, 2015 09:39 PM
20/20 vision
Sep 29, 2015 11:27 AM
