replacing a lame horn
Old Dec 14, 2008 | 09:41 PM
cossiewill.'s Avatar
cossiewill.
Brit With A Tan
Default replacing a lame horn
So i am slowly moving thought my list of stuff to do to my saph and next up is the horn, at the mo it sounds, well proper sad.
So any ideas what to replace it with? have been over in the states for the past 4 years and was thinking of getting a train horn but that would probley just get me in trouble with the rossers
http://urlant.com/yvwjnb
Ww
Old Dec 14, 2008 | 11:02 PM
Rax's Avatar
Rax
There should be two.If ones failed get one to replace off something like a toyota because they are higher pitched.Just my 2p worth.
Old Dec 15, 2008 | 06:04 AM
I have two X NAUTILUS air horns, in place of the original, even used the original horn brackets by bending end piece through 90 degrees, these things are seriously loud, they even fit(just) with RS500 cooler there, then just a simple bit of wire from bracket to horn for earth plug in live each side job done.
The nautilus horns are compact two in one air horns, so a high and low each side.
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
