Anyone removed FRS ecu module?!
Old Dec 13, 2008 | 06:16 PM
R5 COT's Avatar
R5 COT
Exclamation Anyone removed FRS ecu module?!
Hi there!! Has anyone sucessfully remover their ecu from their Focus RS, I have located it in the drivers side footwell and removed the trim below the ecu and the trim below the steering column. the ecu will slide down so far out of it's bracket but not fully as the wiring harness resticts it! the other problem being theres a metal clamp holding the plug into the ecu. has anyone removed it? there seems to be a nut underneath this clamp on the other side which is very hard to get to! It was getting dark so i've left it for today!
Any help appreciated!!
Old Dec 15, 2008 | 08:45 PM
sebspring's Avatar
sebspring
Winker
you won't get the nut off.; it is there to stop you removing it.
cut the bugger out is the best way.
Old Dec 15, 2008 | 10:01 PM
Gaz 88's Avatar
Gaz 88
yep that nut is welded you will have to dig the grinder out if you want to get to it!
Old Dec 15, 2008 | 10:03 PM
R5 COT's Avatar
R5 COT
Lol Cheers yeah I found out today it's a self shearing bolt thats used, so I'm gonna have another crack at it when we have daylight so not till the weekend now!! Or I need a better torch!
Old Dec 15, 2008 | 10:17 PM
focusv8's Avatar
focusv8
Pair of decent pipe grips around the sheared off end of the bolt is all you need, if it's the same as a 1.6 ecu bracket.
Old Dec 16, 2008 | 08:41 PM
R5 COT's Avatar
R5 COT
top man!! I will give it a go on the weekend!!
Old Dec 17, 2008 | 06:00 PM
R5 COT's Avatar
R5 COT
Had A go to day with some pipe grips! yipee lol came off finally!!
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
DixieTheKid
Sep 14, 2015 09:04 PM
RSmark84
Sep 13, 2015 01:29 PM
