Escossie koni problem
Old Dec 13, 2008 | 06:15 PM
YBT200's Avatar
YBT200
Default Escossie koni problem
hi guys, i've just replaced my standard suspension for koni adustable suspension with ahmed bayoo springs and have hit a problem. The spring cups on the front shocks are rubbing on the tyres both sides. The cars is running 18 OZ Super turismo with 225/40 R18 tyres.
Any idea what could be the problem please ?
Old Dec 13, 2008 | 06:21 PM
El Grand Tomismola's Avatar
El Grand Tomismola
Yes - 18's are too big for the Konis.
I had Koni's on mine, where on the car when I bought them, the previous owner had cut the spring cup so the tyre didn't foul the tyre anymore
Brutal, slightly unsafe, but did the Job
Old Dec 13, 2008 | 06:35 PM
paul16v's Avatar
paul16v
Monte 087
You have to slightly reshape the spring cup with a hammer
Old Dec 13, 2008 | 07:30 PM
james kiely's Avatar
james kiely
maybe a 5mm spacer might get you out of trouble.
cheers james
Old Dec 14, 2008 | 11:28 AM
martinembleton's Avatar
martinembleton
i got konis on 18" rondells its fine
Old Dec 14, 2008 | 11:32 AM
The Youth.'s Avatar
The Youth.
as said the spring cup is lower on koni's the best way is to take the strut off then cut a piece out then weld some straight metal in, repaint and refit.
the other way is as said use a big hammer!
steve
Old Dec 14, 2008 | 11:33 AM
KSA-Cossie's Avatar
KSA-Cossie
Modify sounds better m8.
Old Dec 14, 2008 | 03:10 PM
ECOS95's Avatar
ECOS95
What offset are your wheels ? If you have ET25 which is the standard wheel offset you'll need spacers to bring the wheel further out. If you have ET18 you can get away with the hammer approach.
I've got one set of 18"'s that are ET18 they fit after reshaping the spring cup & the others are ET25 & I've got to fit some Eibach spacers to get them to fit.
Old Dec 14, 2008 | 04:11 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
its quite common, if you were closer, id have offered to modify and reweld the cup so it clears,
but i think your a bit far away lol
Old Dec 14, 2008 | 04:19 PM
kjc300's Avatar
kjc300
My 18" Super T's were ET18 and a previous owner had just hammered the cup a bit which cleared it fine.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
