How do you remove the Front Drive Shafts ??
Post Miester !
I want to take the front drive shafts off the escos.
But nto sure how the come out the diff ?? and will all the oil come out aswell ??
try and borrow an electric impact gun to undo the 30mm hub nut, then take teh hub off
but on the drivers side you have to undo the bottom plate of the iff and there is a circlip inside holding the shaft in place, passenger side will just fall out as its not held in by anything
you can also take the gaitor off and pop the shaft out the joint, it will just pull out leaving the joint in the diff
but the diff only takes 0.5 litres of oil, so its not a lot really
Ossie Cossie - to remove the front hub, i'm guessing you want to change a wheel bearing etc. Its best to remove all the hub and get the stud axle pressed out on a decent fly press.
For the right side, you need to open the front diff and remove the clip.
It takes 1 litre of oil...
For the left side, you only have to pull it. Because it's fitted into an spacer, and it' the spacer wich is clipsed into the diff.
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
