Lots OF Grey Smoke At Idle
Old Dec 12, 2008 | 08:17 AM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Default Lots OF Grey Smoke At Idle
Hi guys
I have lots of whitish grey smoke at idle. The engine was rebuilt years ago but has been sitting for a long while. I changed the oil filter cam belt etc etc and it could probably do with being set up but it drives fine.
Just this bloddy smoke. I know the valve stem seals get said a lot but would that not create blue smoke.
Hope you can help as its doing my brain in....
It only smokes at idle.
Old Dec 12, 2008 | 08:38 AM
rich.edrsoc's Avatar
rich.edrsoc
sounds stupid, but is it not just the fact thats it's soooo feckin freezin at the moment and you can see all the exhaust fumes?
Old Dec 12, 2008 | 04:30 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
was gonna say similar thing as above, does it clear after the car has warmed up to full operating temp ????.
dave.
Old Dec 13, 2008 | 11:06 AM
Shep_Cobain's Avatar
Shep_Cobain
Condensation.
Old Dec 13, 2008 | 03:59 PM
Ebonycossie4x4
Thansk for the replys guys..
I thought the same but once its warm it goes away then ill be sitting at lights or just sitting on idle and it will come back for like 20 minutes then go for 20 then come back.
Its so annoying and it cant be much because the car runs so well...
Thanks again
Old Dec 13, 2008 | 06:45 PM
blueskies85's Avatar
blueskies85
id have thought its condensation. If you would have said another colour of smoke then id suggest different.
Old Dec 13, 2008 | 06:47 PM
blueskies85
it reminds me of the time when a friend of mine steam cleaned his engine, just after he put a new head on, he left the exhaust manifold just hanging there and it collected water. When he fired it up and it warmed up it was like a fucking kettle boiling off, shooting plumes and plumes of steam out the exhaust, there was nothing he could do except drive it off, took about a week... the shame of it was so funny though.
Old Dec 13, 2008 | 06:58 PM
Karlos G's Avatar
Karlos G
Balls Deep!
PMSL!!!
He was lucky he didnt get water in the cylinders, break a rod and bend the crank!!!
Old Dec 13, 2008 | 07:01 PM
blueskies85
yeah but the funniest thing was, I told him to park it on a hill and try and see if it runs out and he said "bollocks its the head thats letting in water" he bought another head and dropped a bollock with the cost. Eventually he bit the bullet and just drove round everywhere looking like a red arrow.
Nah mate it was on a normally aspirated engine, god it would have gone wrong if he was on boost.
Old Dec 13, 2008 | 07:03 PM
crazycage's Avatar
crazycage
Originally Posted by Karlos G
PMSL!!!
the water would need to be in the inlet for that to happen and it would hydraulic and push the bore out into the water jacket break the piston where it holds the little end and bend a valve
Old Dec 13, 2008 | 07:09 PM
SO COSSIE's Avatar
SO COSSIE
What car is it the prob on ?? if its a cosworth i had the same prob on an old saff i had it was the map sencer
Old Dec 13, 2008 | 07:15 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It would just have to be in the cylinder above the piston, all he needed was an open exhuast valve to let it in! LOL
Water doesnt compress like AF mix as i'm sure you know!
Something has to give and in my case it was the rod and crank!! Which left me with a hole in the side of the block and a big puddle of oil on the road!!
Old Dec 13, 2008 | 07:20 PM
crazycage's Avatar
crazycage
i cant see how the water would get back up the manifold and down the port on the head ??
blueskies85
must have been a sad moment.
Old Dec 13, 2008 | 07:22 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The manifold was off!!! and he was using a pressure washer!!
It wasnt my RS so it was actually quite funny! lol
Old Dec 13, 2008 | 07:23 PM
JK99's Avatar
JK99
If the car is fitted with a stainless exhaust then it could just be condensation. These tend to make the problem worse in cold weather.
Old Dec 16, 2008 | 02:56 PM
Ebonycossie4x4
Yes guys it is an rs turbo escort and it has a stainless exhaust.
I tend to agree with the condensation but the only thing that was puzzling me is why it goes away and then comes back even when i have not restarted the car
could be siiting at the side of the road ticking over and it will be there. then go completely and then 10 minutes later be back
Thanks for all the replys guys. maybe i will just have to put up with the problem, I can just see the people coing to look at it wondering why its smoking though...
Old Dec 16, 2008 | 04:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
hmmm...well it could be your head gasket then?! Do a compression test.
Old Sep 22, 2011 | 02:49 PM
FSK374's Avatar
FSK374
I have an identical problem on my '78 3.0 Capri, it didn't smoke at idle before the stainless steel exhaust was fitted.
A few hard revs after sitting on idle and no more smoke. Frustrating smoking away at the lights though.
Old Sep 22, 2011 | 04:27 PM
nigel b's Avatar
nigel b
Could be breather system if its on efi or a cracked head
Old Sep 22, 2011 | 04:35 PM
FSK374's Avatar
FSK374
It's a weber 38dgas carburettor.
The car runs sweet with lots of power. I guess whatever us causing it will only get worse. Will post any changes / faults / diagnosis.
Old Sep 22, 2011 | 10:29 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
no smoke when driving, smoke when at idle?
Turbo oil seals....
remedy: Put vacuum on the breather system.
Eigdoog
48
Sep 19, 2015 11:03 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
turbowag
Sep 3, 2015 08:07 AM
