Stage 2 for T34
I would recommend you have your car live mapped as P8 is quite a quirky ECU (compared to L1 - L8) as it is speed/pressure/throttle angle mapped and all stage 2 chips I have tested have been poor, because they have maintained the std configuration throttle angle multipliers which results in an excessive on boost AFR during part throttle high boost operation.
there isnt really such a thing as a stg 2 - most people go to stg 3 , which is green injecotrs, 3 bar map sensor, -31 actuator, running on p8 gives a healthy 330-340 brake with a nice 1.9 bar mid range boost spike for overtaking with.
i had msd install and set mine up - was very happy with the results and it drove much smoother and nicer than just the stg 1 chip that was fitted prior.
Russ Payne
Sep 25, 2015 08:29 PM
