grs intercooler fans
Old Dec 10, 2008 | 09:25 AM
rst230bhp's Avatar
rst230bhp
Default grs intercooler fans
i have just got myself a Grs intercooler and now need to get some fans
what fans do people recommend also what sort of prices would they be
Thanks
Old Dec 10, 2008 | 06:52 PM
bezo's Avatar
bezo
powered by K26
got a kenlow on mine and it works a treat, bought it off GRS at the same time as i got the cooler.
Old Dec 10, 2008 | 06:56 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default fans
it all depends where you want it to go i run mine inbetween the rad and intercooler so use a twin spal fan set up as they dont have the centre nut that sticks out and could damage the intercooler,which the kenlowes do.
if your going to mount the fans on the intercooler then kenlowes are all good, go for a twin fan setup if you can afford it.do you have any temp prblems when in traffic ect??cheers
Old Dec 10, 2008 | 07:12 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I run twin Spal fans on mine, mounted on the IC.
Old Dec 11, 2008 | 07:03 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
kenlow front mounted
Old Dec 11, 2008 | 08:51 AM
Marc LJX's Avatar
Marc LJX
Im just thinking about ordering two 8" spal fans for my build... They are very slim and as said, dont have the centre nut.
Old Dec 11, 2008 | 08:53 AM
Marc LJX's Avatar
Marc LJX
I run a single kenlowe purchased via GRS on my S2 and its mounted between rad and cooler. It overheats on summer trackdays but i dont think thats a fan issue, more a general airflow thing wrt positioning of rad and cooler...
Old Dec 11, 2008 | 11:25 AM
zvhturbo29rs
Default fans
get a second fan marc, i only had one and it would overheat, get a second fan an 82 degrees thermosta and cut the front slightly to aid air flow.
Old Dec 11, 2008 | 12:31 PM
Marc LJX's Avatar
Marc LJX
Front bumper is very modified. Next step would be to remove the centre bar and i'm not doing that!
Already got the 82 deg stat.
Cooling system is fine, with a new rad and a not very old (<10000 miles) gen ford water pump.
Might try another fan if it ever comes out of its bubble again
Old Dec 12, 2008 | 07:45 PM
turbo.jon's Avatar
turbo.jon
I used twin spal fans i got off a merc in breakers yard cant remember what make car it was it was few years ago now
Old Dec 12, 2008 | 09:08 PM
nigel b's Avatar
nigel b
single kenlowe
Old Dec 15, 2008 | 12:26 PM
Linsay's Avatar
Linsay
Having had both - i still have the Spals on mine (on rad) and they are great
The kenlowe has a nut on the outside of the casing (attached to the spinning fan) which nearly drilled a nice hole in one the the GRS intercooler veins, when the intercooler moved slightly when the car was in motion - the spals have all moved parts enclosed in the casing.. and they blow better
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
