dump valves?
Old Dec 9, 2008 | 09:40 PM
Talon's Avatar
Talon
Default dump valves?
looking to put one on my rs turbo, whats the best to go for? recirc?
what sorta sounds does a recirculated one make? what about single and double piston etc? not too clued on them, thinking of leaving it off but has been suggested to get one?
any help is appreciated
Old Dec 9, 2008 | 09:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If you do get one, it must be a twin piston or you'll create a massive air leak, and a recirculating one doesnt make any sound (i think) because it 'dumps' the pressure back into the intake, instead of to atmosphere.
Old Dec 9, 2008 | 09:52 PM
Smartdj.'s Avatar
Smartdj.
u will still hear it dump but not as loud...
Old Dec 9, 2008 | 09:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
oh ok, never actually seen one!
Old Dec 9, 2008 | 10:18 PM
Smartdj.'s Avatar
Smartdj.
they make a wooooosshhhhhyy sound insted of a high pitch noise like bailys ones..
Old Dec 9, 2008 | 10:39 PM
djmillsy's Avatar
djmillsy
Fife Radge
ive got a bailey on mine and it does the job
Old Dec 9, 2008 | 10:46 PM
nickscunny's Avatar
nickscunny
mines a baileys too and it does the job well.....
Old Dec 10, 2008 | 07:12 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
the best thing you can do is not run one on a rst
Old Dec 10, 2008 | 10:04 AM
Brian's Avatar
Brian
I had a bailey one on my old Series 2, took it off after a few months and the car run loads better
Brian
Old Dec 10, 2008 | 01:21 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
As said twin piston only if you're getting one, make sure it's not diaphragm type. Personally wouldn't have one, car will thank you......and they're
Old Dec 10, 2008 | 04:45 PM
kizzy s1's Avatar
kizzy s1
dont do it made my car run bad plus it makes you look like a chaved up boy racer
Old Dec 10, 2008 | 05:56 PM
juffer's Avatar
juffer
A friend took his dump valve off and it chattered, even with the air flow meter. It was fairly loud but not as loud as a cossy. I tryed it on mine by mine wouldnt chatter. It must be to do with how much boost i was running or somthing. I would rather have the chatter any day !
Old Dec 10, 2008 | 06:47 PM
bezo's Avatar
bezo
powered by K26
double piston, otherwise your car wont start due to the extra air being drawn in.
Bailey seems to be the main choice and seems to last the longest.
bezo
Old Dec 10, 2008 | 09:28 PM
studabear's Avatar
studabear
was your mates running efi? mfi won't chatter
Old Dec 10, 2008 | 09:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Oh yes it will!
My Mfi S2 chatters even with a dump valve fitted! But 10x more so without one! If i let off just as the turbo spools up to peak boost (17psi) it will chatter.
Yes it is to do with how much boost you are running, as it's the sound of the pressure building up back to the blades on the compressor wheel and trying to stop it rotating. This is why people say dump valves are good on high boost cars because it stops the pressure build up reaching the compressor wheel and slowing it down..... in theory reducing lag.
Old Dec 11, 2008 | 05:48 PM
juffer's Avatar
juffer
He was runing MFI with 16 psi boost. A MFI will chatter but not as much as EFI because the air flow meter is a restriction
Old Dec 11, 2008 | 06:58 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
Ive just put a set of samcos on mine and put a dump valve (MSD) on it and the tish is loud as hell - better response on boost too.
Old Dec 13, 2008 | 11:28 AM
mark2's Avatar
mark2
i agree
mine seems tobe more responsive with no dump valve even let my mate drive the car for a while with it on then with out telling him removed it one day and let him back in the seat and he even agreed the car responded better and the chatter it makes is quite inpressive and i mean you hear it not a faint flutter in the back ground all on a mfi lump at only 12 psi but remember all engines run different
mark
Old Dec 13, 2008 | 01:24 PM
studabear's Avatar
studabear
oops i always believed mfi didn't chatter(going of info from mates), mite remove my dv in the spring and see if it chatters
Old Dec 13, 2008 | 01:48 PM
jammerrs's Avatar
jammerrs
if the chatter is the air trying to come back throught the turbo, isnt that killing your turbo?
Old Dec 13, 2008 | 01:52 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Not unless you're running more than 260hp MFI....thats the only stage a dump valve is 'needed'.
Old Dec 13, 2008 | 02:05 PM
jammerrs's Avatar
jammerrs
thanks i just always thought they were needed on turbos, learn something new everyday
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
