Leaking sunroof
Old Dec 9, 2008 | 04:34 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
Default Leaking sunroof
I have noticed during my rebuild that occassionally get a small amount of wayer in the drivers footwell. Today i moved the car and found water dripping from the sunroof. How can i stop this?
Also noticed water drips in the boot but only when i open the boot it drips inside, is this normal or if not how do i sort?
Old Dec 9, 2008 | 04:50 PM
dangerousbrian's Avatar
dangerousbrian
both my escorts rubbers on the boot surround had perished..worth a look..but mine always dripped when tailgate opening..its just a build up... as for the sunroof check to make sure the drainage pipes arent blocked, as it will have nowhere to go but the inside of the car if they are
Old Dec 9, 2008 | 07:23 PM
Red_bull's Avatar
Red_bull
it also could be rust around the sunroof, but i think you first should check rubbers and drainage pipes!
Old Dec 9, 2008 | 08:47 PM
notroubleclubber
no rust around the sunroof so will check drainage and was told to put vaseline round seals too.#
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
stevecfrst1
Sep 30, 2015 05:18 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
