Half Moon Seal Problem
Old Dec 9, 2008 | 06:44 AM
Niall.b's Avatar
Niall.b
Default Half Moon Seal Problem
is there a better type of rocker cover half moon seal available? I have tried the thin orange ones twice & the oil keeps leaking down the front of the head even with silicone or instant gasket applied. really need to get this problem sorted once & for all. Cheers
Old Dec 9, 2008 | 07:34 AM
cos47's Avatar
cos47
Are you sure its these leaking and not the cam shaft "o" rings
Old Dec 9, 2008 | 07:47 AM
Niall.b's Avatar
Niall.b
positive, i have cleaned the area & can see the oil weeping through between the rocker cover & the bearing carrier. its completely dry around the bearing & carrier
Old Dec 9, 2008 | 11:45 AM
The orange ones hould be fine I use these, although I put a thin smear of loctite 5900 in the groove just to hold them and at the ends as they always leak here.
Old Dec 9, 2008 | 11:59 AM
Niall.b's Avatar
Niall.b
cheers, going to try resealing it up again later, Tabetha, will try using the loctite this time
Old Dec 9, 2008 | 03:08 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
when i had my rocker cover changed, i had new orange ones fitted and i had the same prob. plus there is a slight spray of oil (only a small amount) going over the air intake samco hose to the turbo
Old Dec 9, 2008 | 06:02 PM
Niall.b's Avatar
Niall.b
same here, got oil spraying around the whole engine bay & underneath right back to the petrol tank. its ruined a brand new timing belt, least its not the sump or crank oil seal as i originally thought
Old Dec 9, 2008 | 06:04 PM
Mark Shead's Avatar
Mark Shead
Not had a problem with seals o the camcover, I would also check the cam cap and put some sealer on the joint where it touches the head.
Mark
Old Dec 9, 2008 | 07:00 PM
broos3's Avatar
broos3
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Yeh use the orange rubber seals and some loctite 5910 or 5900. Tabetha told me to use this stuff years ago and its great. Well worth the slightly expensive price tag.
Bruce
Old Dec 9, 2008 | 07:02 PM
jacko's Avatar
jacko
the ones for suply now are i bit stronger and there clear i use weld seal on both sides and then it never leeks
Old Dec 9, 2008 | 07:56 PM
borderfox's Avatar
borderfox
gen ford ones are clear and a lot better.
would not fit anything else...
Old Dec 9, 2008 | 10:12 PM
Paul_RS's Avatar
Paul_RS
Even i can get this right Niall
I just put sealer round any joints to the rocker cover gasket and mine is ok so far.
Old Dec 10, 2008 | 05:35 PM
big mac's Avatar
big mac
the orange seals i had from woodford were to thin and to short replaced with gen ford clear ones with smear of sealant problem solved
Old Dec 10, 2008 | 07:00 PM
TurboShed's Avatar
TurboShed
Cossiemodo
So why is there so much pressure that it's spraying oil into your engine bay???
Old Dec 10, 2008 | 07:20 PM
Niall.b's Avatar
Niall.b
not spraying as such, as its running down the front of the engine & being flicked around the engine bay by the cam belt & pullies. when driving the airflow underneath the car is carrying the drops along the underside resulting in a very thin film of oil along the floorpan, gearbox, rear axle & tank. just a real pain. have stripped out the cam bearnigs tonight & found a small nick in one of the o rings. will replace this, seal the whole show up & replace the rocker gasket & half moons and hopefully that will sort it. just one of those jobs that takes a bit of time to sort out
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
IainRS1700T
Sep 25, 2015 06:44 AM
krypton
Sep 23, 2015 07:29 PM
biggiejody
Sep 19, 2015 10:25 AM
