Spark plug choice
Old Dec 8, 2008 | 01:56 PM
pauldonachyrs's Avatar
pauldonachyrs
Default Spark plug choice
Ive got a 3 door cosworth running 403bhp and needing set off plugs.
Ive been told to get lots different kind of plugs..
Heres ones ive been told to get from lots different people:
R7435-9 race platinuim plugs
bkr9e1x
ngk bcr8es
iridium bkr9eix ngk
denso dpr900/9r (i think)
also lets here you choice asewll
cheers paul
Old Dec 8, 2008 | 02:43 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
i have been told the standard ones do the job fine really mate.
Old Dec 8, 2008 | 02:55 PM
Twellsie's Avatar
Twellsie
Denso ik27's in mine
Old Dec 8, 2008 | 03:00 PM
pauldonachyrs
how much they rob you?
pauldonachyrs
me aswell?
Old Dec 8, 2008 | 03:01 PM
Kverna's Avatar
Kverna
Virgin-popper
bcr8es or denso ik31's if your pocket can afford them
Old Dec 8, 2008 | 03:36 PM
I'm on IK31's, but 071's can be used around £10 delivered for a set of 4.
Old Dec 8, 2008 | 03:40 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Running a set of NGK BCR8ES's in mine at 450 bhp with no complaints!
Old Dec 8, 2008 | 05:43 PM
ickey818's Avatar
ickey818
I use 071's in mine at 380bhp, seem to work fine.
Tried a set of IK31's a while ago and must admit tick over was smoother and car seemed more responsive but they only lasted 3 months.
Old Dec 8, 2008 | 07:20 PM
bigchez's Avatar
bigchez
Iridiums in mine from Reyland - ticks over beautifully.
Old Dec 9, 2008 | 09:29 AM
Twellsie's Avatar
Twellsie
are IK31's the right heat range? i have had IK27's in mine for over 2 years now without needing to change them
Old Dec 9, 2008 | 09:31 AM
Twellsie's Avatar
Twellsie
about £50 a set iirc
Old Dec 9, 2008 | 11:43 AM
My car just "ate" a IK31, started missing, changed the plugs as no 2 was not doing a lot other than missing!!
Old Dec 9, 2008 | 12:01 PM
Twellsie's Avatar
Twellsie
looks like you might be better off with 27's then I have no idea what the differance is but they are what Karl at NMS put in it for me
Old Dec 9, 2008 | 12:08 PM
costina's Avatar
costina
Live long and prosper!!
Had denso's but started missing on no 4 due to not being driven often
they are difficult to clean if at all
now on 071's cheap as chips and do the job
btw i run a coilpack
Paul
Old Dec 9, 2008 | 12:18 PM
Thanasis's Avatar
Thanasis
NippoDenso K24 - PR - ZU !!
Old Dec 9, 2008 | 02:10 PM
pauldonachyrs
went for the
iridium bkr9eix ngk ones lads
cheers
Old Dec 9, 2008 | 06:52 PM
I'm on accel coilpack, getting some from a buddy to try.
after it had cooled down went out again with Ik31 and it was fine!!
Old Dec 10, 2008 | 10:05 AM
KSA-Cossie's Avatar
KSA-Cossie
Coilpacks and IK31's gapped at 0.9mm in my saph.
Old Dec 11, 2008 | 04:26 PM
Karl's Avatar
Karl
Norris Motorsport
IK31's are too cold as an everyday plug especially during winter time.
Allthough there are excepetions to the rule I usually use IK27's in sub 380bhp, and IK31's for over this power level. However I usually advise something like a Ford 091C if you're just pottering to work and back in winter, regardless of bhp!
Old Dec 11, 2008 | 05:29 PM
Thanks for that, I'll get me some 27's now, it is getting a bit grumpy with the weather.
Old Dec 11, 2008 | 05:34 PM
Thanasis's Avatar
Thanasis
check here mates:
http://www.globaldenso.com/cgi-bin/g...&action=search
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
little bram
Sep 27, 2015 07:45 AM
