Fuel regulator question
Old Dec 7, 2008 | 08:13 PM
RS Juto's Avatar
RS Juto
Default Fuel regulator question
I have a 2wd cossy of which i have just fitted a 4x4 inlet manifold, i am in the process of trying to find a 4x4 fuel rail however my question is will a 2wd fuel regulator fit on a 4x4 rail, if not why ?
Old Dec 7, 2008 | 08:47 PM
mechanic28's Avatar
mechanic28
i have just done the same thing fella!although i fitted a 4x4 rail as well!i think the 2wd reg will not fit onto the 4x4 rail!but you can modify the 2wd rail and reg to fit the 4x4 inlet by cutting one of the locating lug off and moving it into the right place and i think you have to make up a bracket for the regulator to fit onto the plenum!i think there is a 4x4 rail/regulator for sale on her tho chap
Old Dec 7, 2008 | 09:19 PM
RS Juto's Avatar
RS Juto
Originally Posted by mechanic28
i have just done the same thing fella!although i fitted a 4x4 rail as well!i think the 2wd reg will not fit onto the 4x4 rail!but you can modify the 2wd rail and reg to fit the 4x4 inlet by cutting one of the locating lug off and moving it into the right place and i think you have to make up a bracket for the regulator to fit onto the plenum!u think there is a 4x4 rail/regulator for sale on her tho chap
Cheers your right, just pm'ed him
Top man cheers
Old Dec 7, 2008 | 10:36 PM
mechanic28's Avatar
mechanic28
np fella!amazing the difference in size on the throttle body neck!
JK12
33
Apr 26, 2021 12:09 PM
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
155lee
Oct 27, 2015 04:55 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
