Can't rememeber a cvh ever making 110bhp stock? A stock xr2 was 86 bhp!
....and that was only until the cam lobes disapeared and the followers bucketed out.
The early mk2 cvh xr2's with the dft webber carb were actually 96bhp from the factory and the later lean burn engine with the tldm webber was 90 bhp, so you are out with you figures chap!!!!
I thought personally the last 1600 efi in the xr3i was 108bhp and apperantely a much more driveable/torquey motor compared to the older mfi variants.
still nowhere near as good as the ST170 for power per litre but the cvh is far from dead and buried as far as being turbo'd goes
i've got a few cvh spares so will probably stay cvh but if your starting a fresh imo Zetec is the way to go cus at least your cams will last more than 5mins for a start
im going for the efi cvh conversion on mine just because the zetec conversion is too expensive and i like the fact that an old engine like a cvh can still give alot of cars a run for there money
pmsl, i like the idea of building a really strong but as we all know expensive full cvh as it is keeping with the whole rs turbo thing. I mean there are amazing figures coming from them, how does 280 bhp daily driver sound from a 1.6 turbo? yEAh
CVH stock internals (pistons, rods, crank) will be good for between 220bhp and 250bhp, the crank will take a lot more (300bhp), and the rods are the weakest link and have been known to go as low as 220bhp, from what i've been told!
thanks Karlos, i never new the crank would take so much, they reckon the max usable power a front wheel drive car can take is 235 to 250 anyways so I may start sourcing another rs turbo engine and start working some magic on it! Ill change my mind in 5 minutes and be researching a zetec turbo then 5 minutes later a fucking zvh, you know how it is
LOL yes mate i know how it is!
I've always been told it's about 300bhp is the limit for front wheel drive, but to be honest i think in a S2 anything over 200bhp is difficult to get the power down and has massive torque steer.......... but thats what makes them so fun to drive!
Can you try and make your mind up before you make arrangements to pick stuff up and then mess them about? Especially when said item is free!
i said i was sorry mate and i truly am!, its not a case of changing my mind, I would have had the engine off you either way, its just work has decided to fook me around till after christmas.
