brake problem help!!!!!!
Old Dec 5, 2008 | 12:44 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Unhappy brake problem help!!!!!!
A few days ago i had brakes on my series 2, and last night i went out and had no brakes except with my foot flat to the floor, this morning checked the brake fluid reservoir to find it well below the minimum (strange it was topped up a few weeks ago) so i topped it up and still no brakes except if you pump the pedal (with which i noticed the revs went down on the car) or put it flat to the floor!!! have checked the brake pipes for leaking and cant find anything!!! it has had the abs disconnected and has standard discs and calipers, anybody got any ideas?????? cheers jason.
Old Dec 5, 2008 | 02:48 PM
Karlos G's Avatar
Karlos G
Balls Deep!
There is a leak somewhere mate! If its still got rear drums check the pistons, they often leak.
If not, bleed it all up, see what happens, and keep looking!
Old Dec 5, 2008 | 03:35 PM
milesy23rst
PUG 306 GTI-6
Smile
[QUOTE=Karlos G;3783592]There is a leak somewhere mate! If its still got rear drums check the pistons, they often leak.
ok mate thanks for the quick reply, wheel cylinders what about them??? have checked all the connections and cant see any leaks at the front, so will have the drums apart tomorrow and check what you said. cheers, jason.
Old Dec 5, 2008 | 05:30 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
hi again
one thing worth checking is to make sure it hasnt filled your brake servo up with fluid,if u cant see a leak,it could all be in there!
Old Dec 5, 2008 | 06:07 PM
milesy23rst
PUG 306 GTI-6
Wink
ok thanks for that, just out of curiosity how do i check to see if its full with brake fluid???? cheers mate, jason
Old Dec 5, 2008 | 06:24 PM
orion_crazy_carl
orion=mini saff
if u undo the 2 13mm nuts holding the master cylinder to servo off and pull it forward a bit,see if theres ne signs of fluid there,only other real way is to take it off,but there should be no fluid there at all,
Old Dec 5, 2008 | 06:53 PM
milesy23rst
PUG 306 GTI-6
Wink
cheers, thanks very much for your help much appreciated. jason
Old Dec 5, 2008 | 09:03 PM
orion_crazy_carl
orion=mini saff
no problem,let us know wht u find!
btw the servo and master' u can still get from ford but 220 quid tho,aint cheap
Old Dec 5, 2008 | 09:11 PM
milesy23rst
PUG 306 GTI-6
Thumbs up
christ that expensive!!!! I didnt think ford did anything for the series 2's after a certain amount of time??? If it turns out to be the master and servo i have been offered a mint pair on here for £40 including postage, so i should be ok either way, will let you know what i find lol, cheers.
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
