Fuse box help.
Old Dec 3, 2008 | 12:12 AM
mk14dr's Avatar
mk14dr
Default Fuse box help.
Hi, Im having a problem finding the fuse box on a 2006 1.6 focus. I need to repalce the cigar lighter fuse, but unfortunately the drivers handbook was stolen when a window was put through earlier in the year so not only do I not know where the fusebox is, I won't know which fuse I need to replace (without taking out and inspecting each one).
Cheers in advance.
D
Old Dec 3, 2008 | 11:45 AM
RichieST's Avatar
RichieST
The fuse box is behind the glovebox. Open it, squeeze the sides in and it will drop down. You will also need to disconnect the damper if you have one fitted.
Not too sure on the fuse, but I can check for you when i get home if you don't know by then!
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
muzzman1
Sep 30, 2015 08:59 PM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
