how much to install a house rad??
Old Dec 1, 2008 | 09:48 PM
GUZZLER's Avatar
GUZZLER
Default how much to install a house rad??
i want a rad in the garage, i have a rad, where i want it theres a rad the other side of the wall about a metre along, was thinking it could be linked off that.
i can fit the rad to the wall, get a hole in the wall etc.. but wanted to know a rough price on what i should expect to pay a plumber to link it up???
Old Dec 1, 2008 | 09:51 PM
Cameron's Avatar
Cameron
No more than £100 really if you've done most of the work yourself, just a simple drain down tee off and refill really.
Old Dec 1, 2008 | 09:53 PM
Rhys's Avatar
Rhys
As said above. Im currently have a whole new system in my house. Fookin thing
Old Dec 1, 2008 | 09:58 PM
GUZZLER's Avatar
GUZZLER
cool, i was hoping to hear something like that
i was trying to get one of my plumber mates from London to do it but none of them have the time to come up here at the moment.... oh well the joys of moving away
any PF plumbers in Northampton
Old Dec 1, 2008 | 10:04 PM
rapidcossie's Avatar
rapidcossie
mate if you work in a garage as a mechanic you will be able to do most simple plumbing work yourself.
go buy a book and save £100 quid!
Old Dec 1, 2008 | 10:17 PM
studabear's Avatar
studabear
I've just had 6 new rads fitted and a total repipe, paid £350 labour, the did it in a day, includin removing mosta the old 1 pipe system
Old Dec 1, 2008 | 11:52 PM
GUZZLER's Avatar
GUZZLER
Euan, i could do it but i have no plumbing tools & would rather have it checked over by a Pro anyway, by the time i but a few tools, pipe etc i might as well get someone round if it cheap enough. do most other things myself as i'm tight
Old Dec 2, 2008 | 07:31 AM
Twellsie's Avatar
Twellsie
buy yourself this book http://www.amazon.co.uk/%2522Readers.../dp/0276429338
all you will need it a pipe cutter and a tape measure and some push fittings, i did my whole bathroom, sink, bath, shower, toilet, moved the radiator etc, very usefull book
Old Dec 2, 2008 | 07:42 AM
Dalek's Avatar
Dalek
Insert witty remark here
You can't link radiators m8, well you can but it won't get as hot as it should. You need to run the pipes for the new radiator back to the distribution manifolds.
Old Dec 2, 2008 | 07:52 AM
Brian's Avatar
Brian
Just had a word with my mate as he is a plumber and is round here fitting a few new rads for us. He works round here in Essex but he does a lot of work at weekends up your way but he said he is way to busy atm
Brian
Old Dec 2, 2008 | 08:11 AM
rst-s2's Avatar
rst-s2
Red 90 Spec s2 RS Turbo
u can tee in to the other rad as long as you get pipe size correct and dont install a too bigger rad, if its a combi system you have u can easily balance the system to allow for the extra rad, if its a tank fed heating system u have same applys but not good to have to many rads on the system, and please get a plumber to do it lol seen to many DIY go wrong
Old Dec 2, 2008 | 08:15 AM
It's Czech Mate's Avatar
It's Czech Mate
I Pay about £150 normally to have a new radiator fitted ( and moved from current location ), thats including the supply of the radiator and all fittings/pipework
Located in West Mids
Old Dec 2, 2008 | 08:25 AM
Brian's Avatar
Brian
That is cheap i payed £130 just for a rad and that was with my mates discount but he did fit it all for nothing
Brian
Old Dec 2, 2008 | 08:27 AM
Phil's Avatar
Phil
Jeebus
Do these prices include all the piping in the walls? I have one in my lounge that needs moving from one side of the corner to the other. The pipes come out of the plaster just above the skirting board -will it cost extra to have them sunk into the walls?
Old Dec 2, 2008 | 08:31 AM
It's Czech Mate
I'm sure the plumber will sink them for you......its just you'll have to pay the plasterer to cover it all up again!
Old Dec 2, 2008 | 08:21 PM
webbywagon's Avatar
webbywagon
It certainly would cost extra. Chasing walls out is a horrible messy job, and no plumber/installer would do that free of charge. I would'nt and i dont know any of my mates who would either.
To clear up a few misconseptions on here, as long as the boiler is big enough, (KW's)then you can fit another rad directly off the existing, flow and return. Dont cross them unless you have 2 way TRV's fitted. Make sure on one rad at least, that you have 2 lockshields, usually the bathroom is the place. If you have an old conventional system, you may, have to back fill as the system will have been designed with an exact amount of rads, plus they are usually sludged up. If its a combi the filling is easy, you might have to throttle the valves down to balance the system if the new rad is not getting hot, which means your boiler cant cope or your system is full of sludge.
24KW is good for about 6 rads
28KW 7 rads upto about 9 max
30KW 9 rads
upto 35KW will handle 10 rads
All again though is dependant on the size of the house, length of pipe runs ans size etc...
A 28KW will do a great job in a 3 bed semi, but not in a big detached. You get the drift. You would'nt expect a 1.3 valencia enginge to easily pull a 7.5 tonne truck would you.
Webby.
Old Dec 2, 2008 | 08:25 PM
rst-s2's Avatar
rst-s2
30KW 9 rads
Webby.
well put mate!
Old Dec 2, 2008 | 08:33 PM
GUZZLER's Avatar
GUZZLER
Webby
will have to check the boiler, we have 12 rads at the moment!
one of my plumber friend from London was going to post some stuff to me but he's said he will try to get up to sort it
Old Dec 2, 2008 | 08:52 PM
rik-rs's Avatar
rik-rs
rad in the garage, posh coont, we havent even got central heating in the house,
we havent even got a garage, or drive or front garden...
Old Dec 2, 2008 | 10:10 PM
whilee's Avatar
whilee
founder of chicken porn
what you got a shed
Old Dec 2, 2008 | 10:32 PM
Red16's Avatar
Red16
What are lockshields?
Originally Posted by whilee
what you got a shed
pmsl... at a guess i'd say he's got night storage heaters.
Old Dec 2, 2008 | 10:33 PM
rst-s2's Avatar
rst-s2
not the valve on the rad u turn up and down the other one
Old Dec 2, 2008 | 11:01 PM
cosy trav's Avatar
cosy trav
This could turn out expensive as you might end up putting a frost stat in your garage to turn the boiler on incase the temp drops below freezing . The rad will freeze up if its below 0 degrees in the garage and a frost stat bypasses all timer controlled circuits and turns the boiler on iff the temp drops below 5 degrees c . Im doing this in my garage too just to be on the safe side . Best thing is its free for me as im a sparky and have pretty good plumbing knowledge and fitted central heating systems before except the gas side of things . Its easy to fit a frost stat so pm me if you need any advice .
Old Dec 3, 2008 | 06:12 AM
rik-rs's Avatar
rik-rs
what you got a shed
ha
think coronation street, house/path/road, thats how ours is....
no central heating, just a couple of gas fires...and if we want heating in the kitchen, its turn the cooker gas rings on..
fordrallycar
Sep 30, 2015 07:57 PM
