Torque settings.
Old Dec 1, 2008 | 09:04 PM
sheps's Avatar
sheps
Default Torque settings.
As above, for headbolts on a cossie, using a grp A gasket?
Old Dec 1, 2008 | 09:13 PM
costina's Avatar
costina
Live long and prosper!!
2wd
stage 1 20 to 25 nm
stage 2 45 to 50 nm
stage 3 rotate 170 to 180 degrees
4wd
stage 1 45 to 50 nm
stage 2 turn 180 degrees
stage 3 check for 110 nm
Make sure all threads in block are clean and lube bolt theads and under washers
Paul
Old Dec 1, 2008 | 09:23 PM
sheps's Avatar
sheps
Ta very much, its a 2wd head, on 4x4 block, so which applies
Also, i read about leaving the gasket to settle, whats all that about?
Old Dec 2, 2008 | 04:33 AM
There are several different ways/setting to do it, even ford could not make up it's mind!
I do it in stages 30lbft, 60lbft, 90lbft, 120lbft.
Then leave for a minimum of two hours, but preferably longer, where I can I leave overnight, then retorque to 120lbft, as they will have loosened as gasket compresses.
Old Dec 2, 2008 | 07:30 AM
sheps's Avatar
sheps
Thats alot of lbft, did you mean Nm??
Nov 1, 2015 06:53 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
