new here quick question
Old Dec 1, 2008 | 07:37 PM
fow16v's Avatar
fow16v
Default new here quick question
hi im Ryan and im new here, wondering if you guys can help me im trying to find out if the engine in an N reg escort 1.4 8v is a valve safe engine if the cambelt has snapped?
i cant check the car as its not mine but is it worth just slapping a new belt on or leave it well alone?
Old Dec 1, 2008 | 08:53 PM
westus1's Avatar
westus1
cvh's aren't a safe engine
but as you 'll need to strip the timing covers off either way its worth the 5 mins it takes to try a belt on it 1st just in case you get lucky
welcome by the way
Old Dec 1, 2008 | 09:05 PM
rst in breaking's Avatar
rst in breaking
welcome matey
Old Dec 1, 2008 | 09:35 PM
rs1072's Avatar
rs1072
Chuck a belt on mate
Welcome
Old Dec 2, 2008 | 05:09 AM
Welcome, as said bung a belt on, it's going to need a new one anyway, if they were going slow etc when it happened you could be lucky even with a unsafe engine.
Old Dec 2, 2008 | 05:50 AM
St3V3_C's Avatar
St3V3_C
or take the cam rocker things off and compression test.
Old Dec 2, 2008 | 06:07 AM
Aaroncast's Avatar
Aaroncast
safe engines!!!!!!!!!!!!
No such thing!!!!!!>>>>>>>>>>> just damage limitations
try a belt -what can you loose!!!!!!!
Old Dec 2, 2008 | 10:56 AM
fow16v's Avatar
fow16v
the car hasnt been bought yet so just looking at the options, its one of those cheap buys that could make money lmao, if it has damaged the valves im guessing it would probably be cheaper to just change the engine or the head complete?
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
