FAO PC experts
Old Dec 1, 2008 | 03:59 PM
BigChuck's Avatar
BigChuck
Default FAO PC experts
I'm having a few problems with my PC, it keeps freezing, nothing works, the mouse cursor doesn't move etc, after i switch the pc off and on again, it takes ages to come back on and when its loaded it runs slow for about 5 mins. it'll probably last about 20 mins or so then it will freeze again.
i did a system restore then a virus scan (nothing showed on the scan), it worked ok for a couple of days, now its started freezing again
any suggestions as to what the problem is? any help is much appreciated.
I'm using windows xp and avast antivirus. it hasn't been updated for a while tho as my subscription has run out.
Old Dec 1, 2008 | 04:06 PM
Nash_mr2's Avatar
Nash_mr2
first restart your PC and as soon as it starts to come back up start tapping F8 - select "use last known good configuration - your recent settings that worked" then continue to use it and see if it makes any difference, if not, could be Processor getting hot and causing crash (check for dust and shite in CPU fan) also check CPU fan and all other cooling fans are working
Old Dec 1, 2008 | 04:10 PM
BigChuck's Avatar
BigChuck
i'll give that ago, i havn't cleaned out the back for a while.
Old Dec 1, 2008 | 04:12 PM
timrud's Avatar
timrud
I thought Avast was free???
Download something that tells you how hot your running, like motherboard monitor, might give you a clue what is up.
Old Dec 1, 2008 | 04:14 PM
5t1g's Avatar
5t1g
Shotgun Bunter
Do you get any bleeps when you turn the computer on?
If it was over heating you'd get a message when you re-started the computer wouldn't you?
This will probably get moved to the computer room mate, right down the bottom
Old Dec 1, 2008 | 04:17 PM
timrud's Avatar
timrud
I had my PC running at 70+ and it never beeped
Old Dec 1, 2008 | 04:22 PM
RichieST's Avatar
RichieST
Is the hard drive clicking away like mad when it freezes? If so, just leave it and let it do what its gotta do. May be doing a big update or something? Also, try getting rid of any shite that you don't need on there, do a disc cleanup and a defragment, things should improve!
Old Dec 1, 2008 | 04:32 PM
BigChuck's Avatar
BigChuck
no mate its not clicking, it just completely freezes. i ftried leaving it but it just doesn't do anything. i've already done the defrag etc did help either.
cheers for the responses guys.
Old Dec 1, 2008 | 04:39 PM
BM08's Avatar
BM08
http://www.filehippo.com/download_everest_home/ download that and get the temps from it, screen shot the screen so we can see
Also avast is free, you have to input a registration code which can be found here http://www.avast.com/eng/faq-registration-license.html once done it will last 1 year, then just get another code free
Old Dec 1, 2008 | 04:41 PM
JohnnyB's Avatar
JohnnyB
i think its over heating
Old Dec 1, 2008 | 05:07 PM
BigChuck's Avatar
BigChuck
i'm downloading just now
Old Dec 1, 2008 | 05:16 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Sounds more like a hardware issue than software...
Does it do it after a certain time period or after opening a certain program?
Old Dec 1, 2008 | 05:22 PM
BigChuck's Avatar
BigChuck
it seems to happen when i'm on the net with a couple of windows open, thats the only thing the freezes have got in common.
Old Dec 1, 2008 | 05:27 PM
BigChuck's Avatar
BigChuck
heres a screen shot of temps, are they ok?
Old Dec 1, 2008 | 05:44 PM
BM08's Avatar
BM08
all your temps are fine.
Could be a ram issue aswell, it hard to tell unless we see the pc
Old Dec 1, 2008 | 05:50 PM
BigChuck's Avatar
BigChuck
I've just updated the antivirus license, i've got it running at the moment.
that everest is good, thanks for the link
what temps should it run at? when should i get worried about temps, how warm do they get?
Old Dec 1, 2008 | 07:57 PM
Rick Astley
I notice your running some skinning program to make your Windows look different.
Here is my suggestion, if you don't have more than 1gb RAM then purchase some from MrMemory.co.uk - As much as you can afford.
I'm running 4gb in my Laptop now, only cost me Ł30 I think.
Tim
Old Dec 2, 2008 | 03:33 PM
DanRSturbo's Avatar
DanRSturbo
Run a scandisk and defrag on the c: drive, that will tell you if you have any bad sectors on the drive, and may make it a bit quicker. Wiping everything off and starting again could well be a solution. If your worried about heat, take the side panel off and put your hand on the hard drive.
DavidK
Sep 27, 2015 02:55 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Mark Mawson
Aug 31, 2015 07:09 PM
61
Mar 24, 2005 09:11 AM
Azrael
Feb 17, 2005 09:26 AM
